Two receivers one with ppv one without
Username: Danny364
I have a vs extreme and a pansat 2700a(upgraded with b 75)both connected to same dish on vs i get everything fine but on pansat i am not getting any ppvs i am getting everything else.I tried almost everything no luck. On ppvs i get 80%level and 99% quality but it always say scrambled or bad channel .anyidea or any help? Thanks.
Username: Lklives
Post Number: 11325
Missing SOME, not all channels, is usually a scan issue...or a bad cable or connection..or a dish alignment issue...
but since U have ONLY 1 dish and no problems with the Viewsat, then it cannot be an alignment issue
FIRST...try a REBOOT on the Pansat ....using REAR switch, power OFF, for 2-3 minutes, then power ON...see if that solves your problem...in fact , ALWAYS REBOOT first, whenever U have ANY type peoblems..
2nd...check the connections again and the cable...
3rd...rescan the satellites U are missing SOME (PPV's) channels from...
Username: Danny364
Thanks LK i did scan it again and i got most of the ppvs.thank again
