Pansat 2500A..Need help.
Username: Nyc_alien
Staten island, Ny Us
Post Number: 56
Hello All,
I'm using a PAN5AT 2500A receiver. I used the 294 BIN and set all the Autorolls and Autoupdate ON but didn't work. It says "wait for signal" and keep going back and forth. Therefore I turned them off and manually input the keys but still says "scrambled or bad signal". I also did the +8 theory after the keys auto rolled but didn't work either. Is there anything that I'm doing wrong ? Please help. Any help appreciated.
Username: Nydas
Post Number: 3340
You can do one of the two things.
1. enter keys manually after changing autoroll to OFF.
2. If you are in a hurry, you can let the keys roll in fully and then change first number in key 00 and key 01. I have posted a how-to today at
https://www.ecoustics.com/electronics/forum/home-video/380090.html
