Viewsat ultra keys
Username: Viewsatdude
Toronto, Ontario Canada
hey anyone have any info on the veiwsat ultra fix
mine went down sometime between 7 last night on the 15th of august and today the 16th at about 6
dont know how to enter keys manually on this reciever any advise??
P.S.
have Aug 1st key and not working with autoroll on or off. i loaded it through the USB port and would like to do the same this time. i realize it may take a while for the new fix. i am fairly new to this and all the lingo every one is using. again any info on manually enetering keys on the viewsat ultra would be much apreciated. no idea even where to start.
Username: Mrrasec
Post Number: 220
menu,user setting,code menu,(cas=nagra),(dish=010100),dont touch first row(00)
you must change keys at 08 and 09 row for (00keys)
and at 88 and 89 row for (01keys)
00: BF 0D 6F DA DB 69 4D 31 F5 70 2B 40 A8 F8 28 03
01: 63 75 F2 E9 83 31 B5 6F 33 60 5B 1F 36 2D 48 7D
Username: Mrrasec
Post Number: 221
08=BF 0D 6F DA DB 69 4D 31
09=F5 70 2B 40 A8 F8 28 03
88=63 75 F2 E9 83 31 B5 6F
89=33 60 5B 1F 36 2D 48 7D
sorry! i dont speak good english.
thanks alot makes more sense to me now
autoroll on or off when i enter these keys
any specific channel i should be on for BEV
Username: Mrrasec
Post Number: 222
autoroll off,i dont know about bev, i have dish..
good luck!
Username: Hi09
hey guys i tried that entered the keys mentioned above - still same thing no audio no video any special procedures i have a viewsat extereme
Username: Bizouneski
Connaught, Ontario Cannada
autoroll off for b3v.. it work thx ppl...
after 2 year of reading i finally become member...lol...
Username: Dash8300
Brampton, Ontario Canada
I'm a newbie and I want to apoligize in advance if my post seems repetitive. I kinda screwed up today because i read above I'm not suppose to touch 00 however I did...what I have there now is d5 d2 91 84 05 4e b6 18 c5 b7 2d e1 7c be a0 67.
Now I'm afraid I've compounded the problem. I don't recall what was originally in 00 and also I don't understand what savoy meant when he/she said....and at 88 and 89 row for (01keys)
Please can someone just break it down for me. By the way I have the viewsat ultra with the front loading usb.
The guy who aimed my satellite used a pansat to set it up and I'm wondering if that can possibly cause any conflits with entering codes.
yup same here not working with autoroll off
i only have bev sat91
do the bev codes go in nagra 010100, 000100,C10100, or i read 090100 somewhere on this site too. where do they go
Username: Niksa
anybody knows key;s for bell and auto roll what shuld be on or of
Username: Dash8300
I entered these codes for 01 and 02 with autoroll off and I'm not getting no audio or video.
Anyone know of a site where I can download the update to the usb and install on the viewsat?
Thank you.
ok im an idiot forget my last post but correct me if im wrong again
the BEV keys for viewsat need to go into either nagra 080100, 090100, 090500, or 090600 still dont know which on to put them in
currently the keys in the first two mentioned abouve are the same for me right now
Username: Kingusama
Post Number: 228
new keys posted at www.ftasolutions.blogspot.com!!
Username: Curda
something like this in spanish please...I am a beginner
Thanks a lot
Username: D1963
(0901)Bev
D5 -- -- -- -- -- -- 18
C5 -- -- -- -- -- -- 67
4B 1F B2 B8 78 F0 74 CE
9A D1 E0 9E CA 09 41 40
Username: Mrrasec
Post Number: 223
86: 5E 11 CE 7A 0F 82 8D DC 58 E6 27 F6 4B 49 92 CD
96: 4B 1F B2 B8 78 F0 74 CE 9A D1 E0 9E CA 09 41 40
try it for bev
Username: Themangod
Post Number: 156
just use a key grabber
[link removed]
Username: Mrrasec
Post Number: 224
jose , pregunta en "solo hispanos"
Username: Curda
Gracias....lo hare
sweeeeeeeeeeeeeeeeeeeet ty ty ty and ty
anyone else reading this ill explain fully
for my viewsat ultra i turned off autoroll in menu, user settings, options
then i went user settings code mode, chose CAS Nagra, and chose BEV 090100
then entered codes into ROW 08 09 88 and 89. (the only rows that apear)
Username: Spesci
can someone please helpout. I can't get the Bev keys to work. Bev auotrolls have been turned off. I enter the keys but no luck, I always get Scrambed Channel
Username: Dash8300
wasyl....when i go to CAS Nagra...all i see is 00 and 01. I don't see 090100 nor are there those rows. I posted above what i have for 00 and 01.
I don't have those rows showing up that you listed
Username: Dash8300
Ok hold up below CAS I found a few BEV's. But which one do I enter the codes in. I have these ones ...BEVPB and four different BEV's. Now do i enter the codes in one of the bev's or in bevpb?
Never again will i get a paki to install other satellite. He didn't explain nothing...even if he did I prob. wouldn't understand.
Username: Icebjerg
VS Ultra bin
application/octet-streamUpload
08-16-2007_opkey.hex (65.5 k)
Username: Dash8300
"for my viewsat ultra i turned off autoroll in menu, user settings, options
then entered codes into ROW 08 09 88 and 89. (the only rows that apear)"
ok ok i'm with you so far....i'm slowly getting this. All I need now is the codes to enter on these rows and if all goes as plan my bev will be up and running...I really want it to be up and running before the ufc fights coming up.
Username: Curse429
Toronto, Ont
Post Number: 12
menu, installation, code, nagra,
for DN - go to dish 010100 enter these keys;
00: a363f411bca3b1ac
08: BF0D6FDADB694D31
09: F5702B40A8F82803
88: 6375F2E98331B56F
89: 33605B1F362D487D
Username: Curse429
Toronto, Ont
Post Number: 13
Gord,
What is that file u posted ?
Username: Themangod
Post Number: 159
opkey has the new keys there for you load it up.
Username: Whattv
Thanks Mike
Username: Icebjerg
this was the current bin for the Ultra memory stick upload
Username: Curse429
Toronto, Ont
Post Number: 15
where did u get it ? and is there one for VS extreme ?
Username: Dash8300
Gord and kate, neither of your recommendations worked for me. Gord, I downloaded and transferred to usb ...did the update on my viewsat but still no audio or video.
Username: Icebjerg
Go here and try
http://www.totalfta.com/
Username: Dash8300
Post Number: 7
This is so F-ing confusing. at totalfta.com they give codes for 00 and 01. that's the first place i went to because the last update was so easy...just download and on to the usb and install. They have the opkey there but that doesn't work!! what they have there doesn't match BEV 09 01 00. this site and totalfta seems to be giving conflicting info.
Is there anyone whose viewsat ultra went down today and is back up now and if so can you please post the fix???
Username: Chazzy81
Try this for the opkey.
7205_opkey.hex (65.5 k)
Username: Dash8300
Post Number: 8
This does not work...the extention has to be pgm. At least that was the extention of the update i downloaded a few weeks ago when i first got the viewsat ultra. I tried changing the extention...it showed up but didn't install.
Username: Chazzy81
The file is the new keys, so you don't have to manually install them. There is no fix yet for any of the Viewsat receivers to autoroll.
Username: Luna_margarita
Mike Thanks.
How can i dowlod the code for the usb for autoroll i have a vs2000 ultra
anyone noe haw can i get the key for the microyal
Username: Artguy5k
Hi everyone, I'm a newbie. I noticed that when you post the keys, you write "86 Active" or " 96 active." What does that mean???
Example:
DISH-KEYS
(86 is Active Changed Thu Aug 16 16:59:03 2007)
86:BF0D6FDADB694D31F5702B40A8F82803
96:6375F2E98331B56F33605B1F362D487D
Can someone please explain it to me? I would appreciate it.
Username: Great1
Edmonton, Alberta
Hello, Key#'s 00,01..are same as 86 and 96, Active means you only need to update the current Active key, For bev you only need dish 0901 or 0801, and for disnet 010100, For now just trun autoroll off and enter the Active / Current keys.
Username: Traceylynn
Anything new as of tonight Aug. 17, we just went down again and my dad is having a fit because he can't watch his baseball game! lol Thanks!
Hi everyonr i want to now if somebody have the key for the VS2000 ultra way down at 8:25pm august 17
Username: Great1
Edmonton, Alberta
Guys keys are same for all the recivers...just turn ur recivers autoroll of untill there is new bin file out for your recivers and keep updating keys...current Active key is 96(2nd key data line). So u need to update this key...here r the key #'s D0 47 36 5D 5B F2 27 66 56 D0 96 C8 3F 85 AF D9. E N J O Y...
