Pansat 3500 sd remote
Username: Elderst
I would like to know if i can use a universial remote and what is the code for the pansat receiver. my remote that i currently have dont work.
Username: Rtap
FL
Post Number: 286
by it from ebay.
Username: Crazy_greek
Post Number: 1092
Just make sure that is used for Pansat receivers.
Pansat Codes 0000,1668,1010
Username: Elderst
NEED HELP
I have a Q Sat 3500 sd. I need the codes for a universial remote. or where can I get the correct remote to work the unit.
