New member Username: CavamanPost Number: 1 Registered: Aug-07 | I use Digiwave 7200. Yesterday (Aug 12, 2007) I manually input new key and when I save my inputs, there is a flash on TV screen and after that the receiver seems dead, without reaction to controller command or reboot. I tried couple of times, including removing power and trun on, and finally it start to react. but all channel shows "No signal" and signal indication is zero as well. Before I changed key, it showed "scrambed" only. Does somebody have similar experience? or know what is wrong with my receiver? Thanks. |
New member Username: TanhouraPost Number: 1 Registered: Aug-07 | does anyone have the new keys of dish network pls |
New member Username: TanhouraPost Number: 2 Registered: Aug-07 | hello pls pls pls need dn keys |
Silver Member Username: BertoroToronto, Ontario Canada Post Number: 648 Registered: Apr-05 | FC 48 ED 05 5A 6D F6 82 FB 6D 35 30 7F 56 F8 44 active 01 |
New member Username: K3nm3lvinSebring, Florida Usa Post Number: 2 Registered: Aug-07 | whatis bothsetsofkeysplease! |
Silver Member Username: Cartier1Post Number: 570 Registered: Feb-07 | lolita come to my house i will show you the keyz |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2642 Registered: Nov-06 | Cave Man New member Username: Cavaman Post Number: 1 Registered: Aug-07 Posted on Monday, August 13, 2007 - 07:18 pm: -------------------------------------------------------------------------------- I use Digiwave 7200. Yesterday (Aug 12, 2007) I manually input new key and when I save my inputs, there is a flash on TV screen and after that the receiver seems dead, without reaction to controller command or reboot. I tried couple of times, including removing power and trun on, and finally it start to react. but all channel shows "No signal" and signal indication is zero as well. Before I changed key, it showed "scrambed" only. "It's so easy even a caveman can do it" } |
Bronze Member Username: Guanajuatos_bestPost Number: 38 Registered: Jul-07 | NO BODY ANSWERED THE CAVEMAN QUESTION. NOT GOOD |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2644 Registered: Nov-06 | There is no hope for digiwave. |
New member Username: CavamanPost Number: 2 Registered: Aug-07 | SatScanner, I agree there is no hope for digiwave market now, but still hope for fixing my issue, right? as you said, it is so easy ! Tell me how to do. Re-install software ? |
New member Username: CavamanPost Number: 3 Registered: Aug-07 | Actually I want to know if receiver H/W and LNB is broken or not. That is why I need help from your guys ! |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2684 Registered: Nov-06 | Recheck your ant settings in the menu, if you can get in it,if not reflash the latest bin after a factory oringinal, if you can find one .If its still acting in a comma as you say , then ditch it.Get something you'll be happy with and enjoy tv,after all thats the main goal . |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2685 Registered: Nov-06 | I seriously doubt the lnb is causing this problem,its a receiever issue, either corrupted sw, or hw. |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2686 Registered: Nov-06 | https://www.ecoustics.com/electronics/forum/home-video/377721.html thread on receivers for you. |
New member Username: CavamanPost Number: 4 Registered: Aug-07 | Thanks SatScanner. I will try later. |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2691 Registered: Nov-06 | None of us want anymore doorstops,but most of us have one or more.It's part of the evolution syndrome. |
New member Username: CavamanPost Number: 5 Registered: Aug-07 | It works now. The antena setting seems to be lost after I input the new key. I reset LNB type and Freq, it works. |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2701 Registered: Nov-06 | Told Ya a caveman can do it! |
New member Username: Sk7Brampton, Ontario Canada Post Number: 1 Registered: Aug-07 | hi guys, New member of ecoustics family. I have a eaglestar receiver,which is not working since last week.somebody told me that may be i need a new Bin file for my rec.Can somebody help me out. I have no idea how to do all this but i really want to learn so that i can do it by myself from next time instead of paying $$$ every time. plz help me out...... THANKX |
