Help with key grabber
Username: Mdl97
Post Number: 11
does anybody know how to reset my keygrabber.accidentaly hit a button on keyboard and know all that shows for each line is''headtitle404 not found''..this is on each line.please help
Username: Themangod
Post Number: 150
hmmm maybe the one you are using is not a simple one
[link removed]
try that one works well grabbers keys from over 3 websites and very easy to use. hard to mess it up open and displays the working right keys.
Username: Mdl97
Post Number: 12
hey kate my keygrabber is a ...vs keygrabber and opkeymaker2.1.....i still dont know what i did wrong.thanks kate...
Username: Themangod
Post Number: 152
yea this one does not do opkey maker this one is a key grabber and how to enter keys only.
but its one of the only ones thats always working.
download it and enter the keys by remote.
Username: Mdl97
Post Number: 13
i opened it up.now how do i put as an icon on my desktop so i can just click it when the system goes down again.is this possible?my keygrabber is an icon on my desktop.
Username: Themangod
Post Number: 153
extract the files onto your desktop or drag and drop it
you only need the EXE file but some people need the other file.
Username: Mdl97
Post Number: 14
THANKS ALOT KATE....I APPRECIATE IT A LOT
Username: Themangod
Post Number: 154
yea not a problem lots of users having problems with some of the key grabbers so i wanted to make sure users have a working easy to use one.
