SV 4000 no channel scanning
Username: Hummer1875
hi, when i try to scan sattelite it does nothing, and my sattelite signal and quality meter are showing good numbers
pls help me
Username: Nydas
Post Number: 3145
First install BIN 155, which was released two days ago, using your USB drive. Make sure you unzip the file and extract the .bin file at the computer, before bringing it to your receiver. After a couple of switch off and on at the back you will find that the keys have rolled in.
You can then go ahead and do the scans.
