For those having problems with the CS. Once you load and have configured and scanned. Shut receiver from the back (in order to reboot) and once you turn it on it will start rolling keys. This is also a problem with CW as well.
We shouldn't be havng any ar problems with c00lsat (5000/6000) at thisn time. If proper loading procedures are followed the box will work fine. Give this a try: 1. Factory reset 2. Load factory bin 3. Load latest AR bin (144) 4. Factory reset again 5. Go to options and apply your settings, remember to turn on AR 6. Do an AUTO SCAN, (network scan OFF will allow a much faster scan for 110) 7. This may take some time but it better doing this than having problems with the box....
i see 2 bins 144v and norw 144 which one and also where can i get factory bin.on bin 142 i told him how to change keys he still gets scramble or bad channeli guess 142 is not working.
