Veiwsat 2000
Username: Banti
Post Number: 51
hello i purchased a veiwsat 2000, when i started i loaded channels by doing a blind scan, and the signal bar keeps changing it goes up then down. why wont the picture come on my veiwsat. AND PLEASEEE help me with this. do i need to input keys? and how do i go to the input keys section. what bin file do i have to load into it? and what loader should i use...please help i would really appreciate it....thankssssss
Username: Grimreeper
Post Number: 304
go here and register its free and painless read the viewsat section theres alot of good info and every file youll need http://dsscommunity .com/forums/index.php
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 2253
Start with flashing the lasted bin[software upgrade], and antanae settings to match your lnb and switches.[If using any or type ].
Username: Banti
Post Number: 52
thanks so much tons of helppp really appreciate it..if u need any help wid ur receivers let me know im an expert at workin with pansats and other receivers....thanks again
Username: Lklives
Post Number: 10405
huh?..If U're an expert on "pansat and other receivers" why the viewsat questions?...NOBODY here is an expert at everything...we all just share whatever we do happen to know..
BTW...Grim and satscanner can teach u a few things about Viewsats or Pansats ...as can www.totalfta.com
Username: Banti
Post Number: 54
because ive been using pansat for very long and i recieved a diffrent kind for the first time thats why;)..anyways thanks for the help and the sites that was a big helpppp!!
Username: Prfrmnj
Post Number: 2796
Banti - before I forget, you don't need to do a "Blind Scan" for viewsats because they have an option "Network update" "On" by default which will update your transponders when performing a regular scan. Doing a blind scan often results in duplicate channels on your receiver.
However, you really need to read up on this receiver. Most sites including the ones above have a Process I wrote called Performng a Perfect Scan for Viewsat Receivers. I suggest you find it and use it. If you can't find it there, then come and see me at ftabins.net.
Username: Banti
Post Number: 55
thanks alot i got my viesat up and running it is working perfectly..thanks sooooo much by the way where can i get the new bins for all receivers?
