New member Username: Timfly45Ontario Canada Post Number: 4 Registered: Mar-07 | What Dish Net satellite is the one that most people lock onto. Is it 110*or 119* Thanking someone is advance, The Duke |
Silver Member Username: HardrockstrikerPost Number: 924 Registered: Apr-06 | I suggest that you lock onto both. This way you get the full package. |
New member Username: Timfly45Ontario Canada Post Number: 5 Registered: Mar-07 | How do you know what vertical degree to use on the dish for those birds. Tim |
Gold Member Username: PrfrmnjPost Number: 2735 Registered: Oct-05 | Duck - Depending where you're at would be how to set up the dish itself. If you look at the list of reputable sites, you'll see links to different sat calculators. Use one of those to find that out. |
New member Username: Gspot6977Seattle, Wa Usa Post Number: 5 Registered: Sep-06 | Does anyone have the latest bin for dish? I have a viewsat ultra. Thanx |
New member Username: Gspot6977Seattle, Wa Usa Post Number: 6 Registered: Sep-06 | latest bin for dish viewsat ultra? Could someone please post for me ? Read lots of posts and couldnt find it. Everyone have a great weekend! Thanx _ |
Platinum Member Username: LklivesPost Number: 10146 Registered: Jan-06 | [link removed] PFTAUSW-070618U ------------------------------ * Versions - Release Date : 2007.06.18 - Main software : PFTAUSW-070618U - Boot Ver : 0.0E * Change (Main software upgrade) - Bug fixed - Channel Locking Problem (USB Upgrade) |
New member Username: Juzbcuz7Post Number: 9 Registered: Jul-06 | I found that 110 has more of the PPVs while 119 has more of a variety of stations. |
Silver Member Username: Crazy_greekPost Number: 977 Registered: Jul-06 | Hey Duke EchoStar 7 @119.oW From Toronto point your Dish to 229.8 degrees and Elevate it to 26.3 From Timmins 225.7 Elevate 23.7 From Thunder Bay 217.2 Elevate 27.6 EchoStar 8/10 @ 110.oW Toronto = 220.3 Elevate 31.2 Timmins = 216.1 Elevate 27.8 Thunder Bay = 206.8 Elevate 31 With one LNB and Dish you can catch both birds. BTW PRFRMNJ early on the sauce, name is Duke not Duck. (just joking) |
New member Username: Timfly45Ontario Canada Post Number: 6 Registered: Mar-07 | Thanks for the help guys. I'll try and locate the birds today. Tim |
New member Username: Bart66Post Number: 1 Registered: Jun-07 | can someone help me i got a dish 301 and a dish with the card.witch one is the easyist to unlock they both have a high ballencs on them is there a way to do that.thank |
Gold Member Username: PrfrmnjPost Number: 2748 Registered: Oct-05 | Kevin - I'm always on the sauce! LMAO! But thanks for reminding me. Always take it as a joke... Good one... |
New member Username: Bart66Post Number: 2 Registered: Jun-07 | can someone help me with dish? |
Silver Member Username: HardrockstrikerPost Number: 934 Registered: Apr-06 | steve, we don't quite know what you're asking. are you asking how to unlock your rom102 card? if so, what rev is it locked at? if it's at 109 you're out of luck, buddy. |
New member Username: Bart66Post Number: 3 Registered: Jun-07 | ita a dish 500 with a 311 reciever thats all i know. its has a high bill on it |
Bronze Member Username: Coolphat5kPost Number: 23 Registered: Mar-07 | Steve, you have a couple of options. You can pay the bill on the box and continue subscribing or you can buy an fta receiver. You'll need to do a lot of reading on the particular model receiver you choose to buy to become familiar with flashing it. I suggest getting a View sat 2000 or cool sat 5000 due to their performance and reliability. They are also easy to work with. Go over here to Freedom or another reputible fta site to get all the info you need on either box. Cheers- |
Silver Member Username: RunnerguyPluto Post Number: 345 Registered: Sep-06 | |
New member Username: Msand951Riverside, Ca Usa Post Number: 10 Registered: Mar-07 | check out dish network's site. look in installation. they have a pdf file with all the info. Where to aim your antenna and from what zip code. Just look for your zip and it will tell you where to aim. |
Bronze Member Username: Msand951Riverside, Ca Usa Post Number: 11 Registered: Mar-07 | http://www.dishnetwork.com/downloads/pdf/DISH_Pointing_Angles.pdf |
Silver Member Username: BandizzyPost Number: 153 Registered: Jun-06 | why would you be out of luck @ rev 109? |
New member Username: Bart66Post Number: 4 Registered: Jun-07 | i need halp on a panset 3500 sd recieve.if i get thie reciever how does it work and do i need to buy anything else.thanks |
Platinum Member Username: LklivesPost Number: 10288 Registered: Jan-06 | steve...I recommend u go to the unofficial pansat sie BTW...if I had a choice of receivers, pansat would be near the bottom, next to fortec.. |
Gold Member Username: PrfrmnjPost Number: 2750 Registered: Oct-05 | Fortecs make good paperweights! LMAO. I guess I shouldn't talk bad about them, I still have one up and running (for testing purposes!)... |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2187 Registered: Nov-06 | steve clemens New member Username: Bart66 Post Number: 4 Registered: Jun-07 Posted on Saturday, June 30, 2007 - 05:29 pm: -------------------------------------------------------------------------------- i need halp on a panset 3500 sd recieve.if i get thie reciever how does it work and do i need to buy anything else.thanks Order a J-tag cable! |
Gold Member Username: PrfrmnjPost Number: 2751 Registered: Oct-05 | Sat - You hit that one on the nose... |
Platinum Member Username: LklivesPost Number: 10290 Registered: Jan-06 | BRUTAL...No mercy!...But TRUE!...LMAO BTW...I mispelled the link above, its Question...anyone know why when i type thr future-fta link it automatically hilights to YELLOW...its freaking me out...I'm NOT purposely doing it...weird...thats new, started today...and I don't screw with the post edits/fonts/colors etc.. |
New member Username: Sapin23Post Number: 5 Registered: Apr-05 | I in the market to buy my first fta receiver and was told that a Cool Sat 7000 would be great for my Dish Satellite. I cancelled their services a few months ago and went with Time Warner but I'm not happy with what I have. Do you guys think that the Cool Sat 7000 is the way to go? Is there a way to hang on to the EPG instead of updating it a few days or is their a receiver that can hold on to the information? Once I buy my FTA, I'm hoping that I do not have to go up on my roof and turn the dish since I already had services from Dish Net? Is there a Thread for beginners as far as what equipment is needed along with software? Thanks in advance! |
Platinum Member Username: LklivesPost Number: 10358 Registered: Jan-06 | I recommend a coo*lsat 5000, captiveworks premium, or homesat for a newbie who wants to have a simple inexpensive box...coo*lsat has best pic quality if U want best, get a Sonicview 4000 or Viewsat ultra...both are USB ready... |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2248 Registered: Nov-06 | Never Ever get a pandead,pancrap or clone. |
New member Username: Sapin23Post Number: 6 Registered: Apr-05 | I will go with your recommendation on buying a ViewSat Ultra. What other accessories will I need and what software will I need to upload. I noticed that a ViewSat Ultra goes for around $160.00 new on e-bay, is that a good deal? I'm curious why will the Co*l Sat 7000 not be a better version to have? |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2284 Registered: Nov-06 | $160.00 sounds really cheap.Beware it seems it's clone at that price and ebay is notorious for clones. |
New member Username: Gspot6977Seattle, Wa Usa Post Number: 7 Registered: Sep-06 | The best deal I have found on a Viewsat ultra is at SATELLITE DISH EXPERT For $179 they have free shipping and currently are giving away a 1 gig USB flash drive for free with it. And they dont sell clones ..........If you have a ultra, the usb flash drive makes it all so painless. The ultra is a much superior unit to my old unit. Ease of operation,features,speed ect. And it has the best support. Oh, and I have a question: I have been running a Vortex Pro 7700 clone unit for sometime and upgraded to a VS ultra. With the ultra there are a couple channels I liked to watch that Aren't on the ultra.. encore westerns(342) and the scifi channel(122) I have loaded and reset several times, did blind scans and still these two channels arent in there. Anyone know why? I want my western channel!!!! Wahhhhhhh |
New member Username: Gspot6977Seattle, Wa Usa Post Number: 8 Registered: Sep-06 | Update: I just looked at S.D.E and they dropped their price to $175 for the ultra with free shipping and a free 1 gig USB flash drive included. |
Platinum Member Username: LklivesPost Number: 10395 Registered: Jan-06 | John Smith..about the coo*lsat 7000, a PVR unit...do U really need PVR and ready for it? I suggest using www.globalwholesalers.biz when buying products...they are reputable and well known.. |
Platinum Member Username: LklivesPost Number: 10396 Registered: Jan-06 | BTW...if U want the best unofficial Viewsat learning site, go to |
Platinum Member Username: LklivesPost Number: 10397 Registered: Jan-06 | also there is a thread here "recommended reputable sites"...check it out, then U decide.. |
New member Username: Sapin23Post Number: 7 Registered: Apr-05 | I really don't care 4 PVR but I will visit the other websites provided, thanks for the info guys! |
New member Username: Gspot6977Seattle, Wa Usa Post Number: 9 Registered: Sep-06 | question: I have been running a Vortex Pro 7700 clone unit for sometime and upgraded to a VS ultra. With the ultra there are a couple channels I liked to watch that Aren't on the ultra.. encore westerns(342) and the scifi channel(122) I have loaded and reset several times, did blind scans and still these two channels arent in there. Anyone know why? I want my western channel!!!! Wahhhhhhh |
Bronze Member Username: GastrognomePost Number: 39 Registered: Dec-06 | do a tp scan-echo7 tp 12414-EWSTN tp 12326-SCIFI |
New member Username: Gspot6977Seattle, Wa Usa Post Number: 10 Registered: Sep-06 | Thanks Gastrognome I'll try that !!! |
Platinum Member Username: LklivesPost Number: 10409 Registered: Jan-06 | whenever U are missing ONLY a FEW channels (NOT ALL)...just go to www.lyngsat:com to the sat U want, and channel U want and check the Transponder TP ...and then scan that TP with your receiver, don't rescan the entire sat or a blind scan...cause if U do , then U will have double channels...and do a TP scan should retieve those FEW missing channels for U...U may want to reboot the receiver again too... also if U have auto TP on in receiver, usually it will auto pick up new tp changes, which may happen often.. |
Bronze Member Username: Gspot6977Seattle, Wa Usa Post Number: 11 Registered: Sep-06 | Question: I have a VS Ultra and I'm trying to edit duplicate channels. But when I push the OK button to delete a channel the box freezes up and I have to beboot it, sometimes it will let me do one edit,other times none. Any suggestions or solutions? thanks in advance |
