Username: Nyc_alien Staten island,
Ny
Us
Post Number: 49 Registered: Dec-04
Friday, July 06, 2007 - 15:45 GMT Hello All, I'm trying to use single dish which I'm using at the moment for 2 boxes for 2 rooms. I have 1 DISeQ installed for the only box I have. What do I need if I want to connect 2 boxes using 1 DiISqE ? Do I need anything more than a splitter ? Need help.
Username: Aanaa Post Number: 181 Registered: Mar-05
Friday, July 06, 2007 - 15:59 GMT not spliter. lnb with 2 outlets take 1 cable thru 1 diseq to the box another cable from lnb to 2nd diseq then to box hope its clear
Username: Satscanner Beaversbush,
Sportsmans P...
Great White ...
Post Number: 2255 Registered: Nov-06
Friday, July 06, 2007 - 20:00 GMT If you have single output dp lnb use a dp 34 switch and set your antanae settings for same.You never said what receiver or lnb type,so we're offering options .Dp34 will allow you 4 recievers.and 3 sats [must have dp lnb]
Username: Lklives Post Number: 10369 Registered: Jan-06
Friday, July 06, 2007 - 20:25 GMT U need a DUAL LNB or a Twin LNB (has 2 ouputs) on your dish...any kind of DUAL LNB..either dish pro (DP) or legacy..
Sportsmans P...
Great White ...
Post Number: 2261 Registered: Nov-06
Friday, July 06, 2007 - 20:34 GMT Dp lnb single and dp34 switch for 4 recievers 3 sats,can be cascaded also.
Username: Lklives Post Number: 10372 Registered: Jan-06
Friday, July 06, 2007 - 22:33 GMT Just remember DP switches are ONLY for Dish Pro (DP) LNB's...disques are good for most all lnb's..
Ny
Us
Post Number: 50 Registered: Dec-04
Friday, July 06, 2007 - 23:11 GMT I have a 2 single LNB's and 1 DISqE. Looks like I have to install another LNB and a switch. Thank you everyone for valuable ideas.
Sportsmans P...
Great White ...
Post Number: 2283 Registered: Nov-06
Saturday, July 07, 2007 - 05:36 GMT If there not dish pro,then yes.
