what is the new pansat autoroll..I need it so that the keys in my pansat can jsut come automatically instead of me always manually entering it..can someone pleaseeeeeeeeeee help...and where can i get it from?
Banti the bin file you load into your stb is what changes the keys. all you need to do is download the file and turn autoroll on. you can go to future-fta*info for files.replace the * for a .
thats an old bin file....go to futurefta.com download the the boot file B-75 and then flash your receiver with bin 203 thats the latest autoroll bin file that came out on april 11th and still working like a charm. All of the instructions are in the the package that you would download. But make sure you follow the instructions properly becuase one mistake could cost you alot more.....
