Echo 3 - 61.5W. LNB type - Standard Freq.: 11250 22KHz off skew - usually -45
A blind scan for the first time, preferably with AutoTP and Autoroll off. If some TPs do not come in after a Blind Scan, add specific TPs. BIN should be 293T. DiseqC setting in software should match the physical connection, i.e. 1/2 or 1/2/3/4.
LOL...I love the blind leading the blind...no offense, U are asking a honest question, but NOT providing enuff info for anybody with any true FTA knowledge to give U a legit answer..
There is NO way anybody can give U sensible advice WITHOUT knowing some details like:
what type LNB's? what switch type? what port is your 61.5 LNB cable ouput to? how many sats/LNB's and receivers? if others, how are they cabled and switched?
Thats just a starter...but let nalin , answer U blindly, she's good at that!...loves to hear herself talk!...has NO clue but she will reply to U, after bashing me, cause thats what she does best to everybody here, especially knowledgeable people!
Hey fortechuser What Bird are you trying to scan in for the Indian Channels. EchoStar 3 @ 61.5W, Anik 3 @ 118.8W EchoStar 9 @ 121.oW or EchoStar !/2 @ 148.oW?
Then your dish is NOT properly aligned and/or the antenna dish receiver settings are NOT correct..and again what type LNB's do U have..Kavin has the right idea, start by telling us what sats U want..
I have fortech star life time ultra with bin 293T. I used to get all channels including Indian till 2 weeks back with 286T. So I'm thinking my dish alignment is not a problem.I want echostar settings for 1/2,7,8/10 or settings for echo star which will catch Indian channels.My LNB type is dish-pro. thanks
So far LK has only interrupted without giving an iota of new information to you. So LK, buzz off and stop your ridicule, since you are the only person to be riduculed at. When you scan any of the sats through your software setting, you may get some channels. They are NOT related to the sat you think you are scanning, but to the sat you are physically connected to. So when you say "Same set of channels are coming for every EchoStar.", what you are doing is scanning the same sat whatever you think you are scanning. If you go up and down with the channels you will see in the bottom left the actual sat you have scanned. That is the physical connection you have. You said "I want echostar settings for 1/2,7,8/10" i.e. you are asking settings for Echo 8.1 at 110W, Echo 7 at 119W and Echo 1/2 at 148W. Echo 1/2 has the Indian channels. You can't get these three together from one Dish. You have to have at least two dishes one for Echo7/8.1 and the other for Echo 1/2. You have to be located midwest or further west to catch Echo 1/2 at 148W. In the East people usually scan Echo 3 at 61.5W for Indian channels. Post more details. do not listen to LK who is big pest always wanting to post everywhere and telling you off for no reason. Kevin is OK and he will guide you properly.
Thanks Nalin,As you said I have 2 dishes. I'm in california. why I'm not able to post details b'coz some one from shop came and fixed the dishes and scanned echo 1/2, echo 7, echo 8/10. We used to get Indian channels from 1/2. All other channels from echo7, 8/10. I changed the bin to 293T and i forgot to writedown previous settings. that's what happened. Previously my LNB setting is dishpro and all other I don't remember . I know entering keys, entering bins. Don't know much about.thanks for ur help
For Echo 7 (119W) use LNB=DishPro and DiseqC setting of Port 1 For Echo 8.1 (110W) use LNB=DishPro and DiseqC setting of Port 2. For Echo 1/2 (148W) use LNB=legacy and DiseqC setting Port 3 or 4. For most of experimenting you keep the above DisEqC settings and change LNB types. The following URL will give you a lot more details. http://www.superfiles.biz/connect_Dish_500_to_receiver.htm
Remember that you have to have at least one Sat scanned to be able to access Nagravision Keys and autoroll settings. Also note that BIN 293T BIN is good, but once the receiver is functioning, keep autoroll and antoTP off for least number of spontaneous resets.
Presuming your watching echo7 and echo8.10, along with echo 1/2.. with DP lnb's type, and its pointed correctly.. if this is the case, then your antenna settings should be just this..
lnb type = dishpro ocs-dp freq 11250 ..thats for all sats.. echo 7 should be #1 echo 8 should be #2 echo 1/2 should be #3 or #4 depending on how U cabled it save settings on all sats
Use the SAT button on the remote to select Echostar package.. hit "ok" 2x then watch tv ...
If U have duplicate channels.. just do a factory reset from main menu.. set your antenna settings as I suggested above and then you BLIND SCAN
I don't have Legacy in my LNB list. I have standard, SINGLE STACK,Dish-pro,Universal 1,Universal 2,Single-SL,Single-SH . Mine is pansat 2500 clone. Thx
I forgot to mention the quality is coming up for only diseqc #2 for all Echos. Do you want me to load factory flash and bin 293 again. If so can you tell me the procedure thx
fortechuser : You have to go into installation/antenna, select each sat and then enter the DiseqC for each. You select Echo 7, and set DiseqC port 1 - then You select Echo 8.1, and set DiseqC port 2 - then You select Echo 3, and set DiseqC port 3 or 4. After that you go out of antenna and select each one separately and do a blind Scan. Then do further experimenting.
If you want to, you can reinstall BIN 293T. Sometimes there is difficulty installing BIN 293T - in that case, install BION 280T first and then install 293T. Many people forget toresotre the user settings and time,date and time zone.
When you are trying, keep the DiseqC settings as above and experiment with changing LNB types, if you are not sure which LNB you have. For Echo 1/2 (148W), you may find Standard LNB may work best in the software settings.
fortechuser : LK is out to make trouble. first he will not help. Then when somebody tries to help he will harras that person. Then he will be sweet withe questioner. Then he will shoot at the questioner. Just ignore him. I have two Pansat 2500 clones and very conversant with them. I am posting from my experience. Lk does NOT have a POansat 2500 or a clone or a Fortec Ultra, but he wants to keep on harrassing. For 293T BIN do exactly as I said and don't listen to the main menace at Ecoustics.
Nalin , I did as you said and reinstall 280t, 293t. No luck. I'm not getting any quality for diseqC 1,3,4 for any sats. X-85BL_070411_293T_api-Full Jtag and X-85BL_070411_293T_api both came together right, so I installed both . After this I observed there is no quality for diseqC 1,3,4. Does the box works if I install flash file and 293T. Thanks for your help.
Is because of using "X-85BL_070411_293T_api-Full Jtag" file before " X-85BL_070411_293T_api" I'm not able to get quality for diseqc 1,3,4. How to get quality for diseqc 1,3,4? Nalin can you help me ? Sorry , I'm really behind you. Thx
LMAO...the bLind leading the blind...pal , U do whatever nalins says, I hope U do not ruin your recievert PERMANENTLY...but I really don't care either...I warned U...u're the idiot for coming here and listening to that crazy bi*tch...
fortechuser : Do not use the full jtag file. Use the other one. Go back to 280T file (NOT full jatag, but serial load), then load 293T. I am not able to answer you for the next one week.
