Cs4000pro help!!
Username: Fastbeatz
Post Number: 111
my cs4000pro keeps turning off every 2 min...then turns off...it pisses me off how it interupts this often...what do i do to fix it?? plz help
Username: Fastbeatz
Post Number: 112
*then turns back on....the off again then on...aaaah
Username: Lklives
Post Number: 9914
reload the factory 120 bin, then the 143b bin..
Username: Fastbeatz
Post Number: 113
where can i find those???
Username: Lklives
Post Number: 9917
Future FTA - Blacklist's Site:
[link removed] (C00LSAT and All receivers)
DSS Newbies:
[link removed] (Pantecs,all clones and all receivers)
File Share Site - No Registration Required:
Good for gettting Original factory firmware:
[link removed]
Best site for DISHNET info, channels, transponders and changes etc..
[link removed]
[link removed]
www.filez.us/km3/keys.shtml
Username: Nydas
Post Number: 2810
fast beatz: LK does not know where exactly you will find your files.
Try one of the following URLs. Make sure you register and become a member - it is free.
[link removed]
http://www.totalfta.com/forumdisplay.php?f=111
Username: Lklives
Post Number: 9918
nalin..the copy machine...she couldn't find her azz with 2 hands!....LMAO...what another wasted post by her above!...no new info, just copied what I already provided
here's the factory bin, loader and 143B bin..and more!
[link removed]
Username: Nydas
Post Number: 2811
LK: Instead of critising me, why did you not post the url in the first place? The problem with you is that you never have the answer and you are too lazy to look it up or to research.
Username: Lklives
Post Number: 9923
The files could be found at any site I provided...and I don't like to spoon feed newbies...they don't learn like that...so STFU nalin!...U are a Loser!
BTW...why didn't u provide the direct link?....cause U CANNOT FIND ANYTHING EXCEPT WHAT I POST!...U ARE MY OWN PERSONAL COPY MACHINE....I OWN YOU PIG!...LMAO
Username: Nydas
Post Number: 2814
LK: Idiot - Can't you see that I provided not one but two direct urls?
It is the same problem with you all the time. You never read the questions properly, are too immersed in your own posts to see that somebody else has already provided the exact answer, and too lazy to look for the answer yourself.
Username: Lklives
Post Number: 9926
nalin...we all know u are a narc for the authorities and ONLY here to create trouble and monitor our activities....why don't U hit the road!
Username: Therepo
Ftaview.com
Post Number: 39
"my cs4000pro keeps turning off every 2 min...then turns off...it pisses me off how it interupts this often...what do i do to fix it?? plz help"
Go back to 142 bin if you have loaded 143b. There is a glitch that triggers rebooting. Or turn autoroll OFF, but preferable to load 142 as it autorolls fine.
