Viewsat Ultra not seeing sat 110
Username: Bishopxman
I need help finding satellite 110 on Dishnetwork. I currently subscribe to Dish and have the 625 DVR. I get sats 119 (port 1), 110 (port 2), and 105 (port 3). My problem is when I use the same line coming in for the Ultra (straight run without the power inverter) only the 119 shows up (getting 120 channels). Here are my settings:
Echostar 7 119.0W
on
OCS-DP
11250
off
12282
port 1
off
none (SW21-Dish1 from my 625 DVR)
I have the super dish outside with the HDTV lbnf (105 degrees), with the digital lnbf and dppp44 switch. I have tried all of the frequencies for 110 but the only matches come up 119, not 110. Also, is there a new file for getting satellite 105 on my listings? I have tried turning the lbn power off on 119 but still cant get 110. I should mention that I am in SC, if that helps. Using bootloader 0.0E, SW PFTAUSW-070523U, satellite U007. Any help would be appreciated.
Username: Lklives
Post Number: 9837
Need to input settings for 110 and 105...
I put the same settings in for 110 as I did for 119 except I used port 2. It started working last nite but today I cant get a signal. I comes with I turn the unit off and back on but after finding the satellite it then loses all signals. I connected the wire back to my dvr 625 and it is working fine. How can I get the settings and the satellite to stay?
