All channels freezing?
Username: Brucelee
Beverly Hills, California United States
Post Number: 86
Hi guys,
not sure buy all my channels are freezing on my VS Platinum? Hasn't happened before, should I default and rescan? Or should I install a new file if there is one?
Thanks!
Username: Tapeman
New York, NY
Post Number: 981
What do you mean by freezing?
Is it that cold in California?
Man here in NY 32 degrees on Easter afternoon!!!
DN Reset once from switch
BeV input Keys Manually
Username: Prfrmnj
Post Number: 2585
Load new pgm file and problem solved. New files are out for viewsats.
Username: Hawaiian_time
Kanaka freak...
Post Number: 1013
There is a new bin out. You could try reinstalling same bin or new one.
Username: Tapeman
New York, NY
Post Number: 982
I advice people not to rush loading new bins with possible bugs
None of them got anti-freez
Use your hands
Username: Brucelee
Post Number: 87
I thought I said channels freezing? But oh well, the DN Reset worked.
Thanks for that!
Happy Easter!
Kanaka freak...
Post Number: 1015
Yes best to let others try new bin first so that you'll learn about problems before you use it.
Username: Cartier1
Post Number: 389
i have viewsat ultra i use the new bin 07-04-07 it's smooth . like smoothy and dont frezz like pinacolada. and bev autorolling so far .
if anyone has channel freez problem just put the reciver next to the heat directly hahaha
Username: Tapeman
New York, NY
Post Number: 985
You are smart guy Hawaiian
