61.5 not workin for me????? no signal????
Username: Jbourikos
Post Number: 25
i only have signal on one tp.....
i cant figure it out????
my other sat is working and is connected using a switch to my receiver
i changed the lnb on 61.5 (it worked for 30 mins) stopped working (no signal)
changed the rg6 cable....changed the switch two times.....
tried all software settings ...tried factory default....tried loading bin over again.....
im guessing its a hardware problem but i dont know what else to change.... my dish is aimed perfectly and is very stable
there is no interference across the street either...its all open
please help
thanks
Username: Lklives
Post Number: 8364
Never change an LNB ,cable, connector or switch when receiver is powered on...in fact always UNPLUG it first..U could blow a switch or LNB in 2 seconds otherwise..
Username: Jbourikos
Post Number: 26
i know lk...thanks...i did power it off at the back and actually unplugged it too while doing work outside...
Username: Jbourikos
Post Number: 27
the messed up thing is that the cable shows 72 but it cant find a signal (actually one tp does 12676 i think...it shows 72 50....)
all the others dont have any signal on them???
Username: Jbourikos
Post Number: 28
thing is that the bev works perfect on it just this dish wont pick up...i have 2 dishes hooked up to it using a switch and i changed switches 2x lnbs 1x cables 2x...i dont know what is causing the signal loss on that dish
Username: Jbourikos
Post Number: 29
any ideas???
im gonna try a new lnb tomorrow morning and see how that works out....but i dont think that it is an lnb issue....
i will also try aiming another dish at 61.5 and see if that helps (but this is my last resort if i cant get anything to work)
help please
Username: Tapeman
New York, NY
Post Number: 782
What dish do you have?
LNBs? Linear or Circular
Receiver?
DISEqC?
What/How many Sats are you looking for?
List hardware U got
U'll up and runing in few minutes
I smell alignment problem. along with DP plus
Username: Cartier1
Post Number: 333
JB . you need to provide information so that your problem can be solved. dont buy any lnb's you may waste your money .
what receiver you have? pansa viewsat cool or whatever . ?
how many sat are involved ? what type pf lnb's do you use?
what type of switch you use ?
what is the configuration you have in your receiver?
if u provide this information your problem will be solved then .
Username: Jbourikos
Post Number: 30
i have tons of sat parts so im not worried about that....
ok this is the setup
inside:
viewsat ultra (latest bin installed march)
rg6 cable running to it from outside
outside:
switch connected to two sats
bev 91 (works perfect)
dish 61.5 (does not work except for 1 tp)
bev dish is bev brand with dishnet lnb
61.5 is dtv brand dtv lnb
i have had them working for 1.5 years and just the other day the 61.5 decided to give me a little trouble
i powered off the box and unplugged the coax and the power
went outside:
changed lnb and switch
went inside:
worked for about 30 mins and then same thing
says no signal
loaded bin over after loading factory 3x
factory defaulted etc....
changed coax outside from dish to switch
tried so many different things....
im gonna run some more tests on it tomorrow but i was trying to find out if anyone knows of more tests i can try to determine the problem
the bev works perfectly and it even reads the 61.5 in the antenna settings
settings are as follows
61.5
11250
standard
port 2
(it reads the dish as echo 3 as well with full signal but only 1 tp has quality)
91
11250
standard
port 3
(it reads the dish as nimiq 1.3 as well with all tps full signal and quality)
Username: Tapeman
New York, NY
Post Number: 785
You still didn't answer me
What dish and size?
What LNBs do you have?
- I got the part U say viewsat receiver
- Everything was working for 18 months
- 61.5 and 91
I have to assume U got 2 dishes because the only other way you'll get them is a super dish.
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 1534
Try hooking the coax directly into the receiver,bypassing all switches,and rescan.
Username: Jbourikos
Post Number: 31
i was gonna do that next tomorrow morning...straight in
one is a reg 18in generic brand dtv lnb(61.5)
other is a expressvu dish 20in dishlnb (91)
thanks for all your help so far everyone
james
Username: Cartier1
Post Number: 339
jb remember lot of tp's has zero signal in echo 3. echo 3 ahs only 173 channels . try tp 12472 and see if it gets the signal ; check if ur dish has moved. the best way bypass the switch use stright cable to the receiver and see what happen . orrrrrr if u got an other reciver see if it works with that . just to have peace of mind that there is nothing wrong with your receiver .
dont buy lnb's dont waste money . if u get level high that mean the lnb is fine .
Username: Jbourikos
Post Number: 32
thats the thing...i checked all the tps (mysteriously one of them has 50%q on it all have 70%s) none of hte other ones work
i know 61.5 well and know that every other tp has channels instead of each and every one
i will try straight through tomorrow and see...i will try my other boxes as well and see if they can get it....
i have tons of sat parts...lnbs...switches...cables...etc...im not worried about wasting money since i already have enough parts to make my house look like a space station :p
thanks guys i will give it a shot n get back to u with some results
james
Username: Crazy_greek
Post Number: 798
Hey JB
A) Check your Coaxial Fittings.
(loose connection,short, or moisture)
B) Ajust the direction of your Dish.
Username: Janilove
Have pansat2700a just bought that was working fine wiht bin file _297 api..I got new file from pansat.com B-75 with boot.. now everything is gone i get 50 TP full SIG but no prgrm found over n over again..Help Help pls..Was tryting to go back to old prgrm still shows file on my box.. if any one knows how can i totaly flash system, and work with old prgrm pls .. Advvise..
jani
Username: Lklives
Post Number: 8564
Jani..read these..
[link removed]
[link removed]
Username: Janilove
Need help for pansat 2700a i got SIg on 61.5 still no Indian pakistanio channel.. got Echo3 as well Pls advise how to get Echo 5 for i am in ILL chicago area have dishpro SW44
Post Number: 1654
https://www.ecoustics.com/electronics/forum/home-video/339687.html read here ,might help u.
Post Number: 1655
https://www.ecoustics.com/electronics/forum/home-video/343411.html Sorry mean here.
Username: Kc4njx
Bradenton, Fl Usa
Post Number: 7
are u sure ur on the 61.5.. direct tv has a bird at 72.. if u thing in dought always go to the left of the sig and come back..if u get sig ur on the 61.5 if ur get sig to the right its the direct 72 bird... remember, it not tv its a hobby too.. good luck bob..
