What did I do wrong
Username: Leona
Toronto, Ontario Canada
I have a toshiba LCD tv, a pioneer DVD recorder and am on bell express vu STB for condominiums. I have managed to connect the express view to the tv but have run into a problem with the DVD recorder. I can watch DVD's but I can't record. I think I missed some connection somewhere. Can anyone tell me what I did wrong? Thanks
Username: Alright_boy
Post Number: 38
Provide info on your DVD recorder connections.
Username: Tapeman
New York, NY
Post Number: 795
No problem at all
Check input selector
If you run wires or cables to DVD recorder let say input#1 then you must select from remote control input#1. If you do so you should see Bell Express program on TV
Good luck
Need to Register?
Forgot Password?
Enable HTML code in message
