LK null cable question
Username: Rtap
MIAMI, FL MIAMI
Post Number: 55
LK i know there is difference in cables but when you
purchase the 3500 it comes with the cable. can you tell me which cable it comes with.
Username: Leew
XXXX!!WWWW, Yokosuka, ... Holla Back Y...
Post Number: 1394
RTAP
I am not LK
but:
Pansat 1500a - Straight DB9 Cables
Pansat 2300a - Straight DB9 Cables
Pansat 2500a - Straight DB9 Cables
Pansat 2700a/e - Null Cables
Pansat 3500s/sd - Null Cables - (Also SD Memory Card)
Pansat 5000HC - Null Cables - (Also can program through USB)
Pansat 6000HXC - Null Cables - (Also can program through USB)
Username: Brucester
Post Number: 310
you guys got to look im starting to see what makes these guys mad got this no more then 20 or 25 post down List of FTA Receivers & Update Cables Used
Here is a list of FTA Receivers and the Update Cables they use.
Anybody that has something not on this list please post here..The goal is to get em all on here!
-This is for PC to Receiver, not Receiver to Receiver.
Null Modem Cable (twisted)
Ariza Ultra 400
Ariza Ultra 500
Ariza 700
Ariza 750
Ariza Xtreme
Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II, MS1000, etc.)
BlueJay2
Buzz S2010F
Buzz S2010F Plus
CaptiveWorks 500S
Captiveworks 600S
CaptiveWorks 600P
C0olsat 4000 Plus
C0olsat 8000 HD
Coship (All)
Conaxsat
DGStation Mutant 200S
DGStation Relook 400S
DGStation Relook 300SV
Digiwave 5900C
Digiwave 6800
Digiwave 7000
Digiwave 7200S
Dreambox (All)
ExtremeView Magnum XV3300
Fortec 5000v2
Fortec 5400 NA
Fortec 5400
Fortec 5600v2
Fortec ALPHA
Fortec BETA
Fortec Lifetime Classic NA
Fortec MERCURY II
Fortec Platinum NA
Fortec PLATINUM
Lava 2600
Lava 3500
Max 2500
Microroyal (All)
MvIdea FS 4000
Orasat V5
Pansat 200A
Pansat 300A
Pansat 330A
Pansat 500 CI
Pansat 700H
Pansat 2000V
Pansat 2700A
Pansat 2700E
Pansat 3500S
Pansat 3500SD (and SD card)
Pansat 5000HC (and USB)
Pansat 6000HCX PVR (and USB)
Pantec/Multistar Max (All)
Rex1
Satcruiser
SatPros DSR500
Silver Bullet/ST 1000
Silver Bullet/ST 2000
Skyview RX600
Sonicview SV1000
SonicView SV1000PVR & usb cable & usb memory stick
Sonicview SV4000 & usb memory stick
Sonicsat Koolsat
Spacestar DVB500
Stealth 2000a
Technosat 1010 Plus (Digiwave Clone)
Techsat
Ultrastar 5000
Viewsat VS2000
Viewsat Platinum
Viewsat Extreme
Viewsat Ultra (also USB)
XRica X5
Straight Thru Cable
Astrovox 2600
C0olsat 4000 Pro
C0olsat 5000
C0olsat 6000
C0oltec
Digiwave Diamond
Eagle Star 2500A (Clone of Pansat 2500A)
Fortec 5100 Diamond
Fortec 5100 Plus
Fortec 5100 Plus+
Fortec 5100 Ultra
Fortec 5600 Plus
Fortec 5600 Ultra
Fortec Lifetime Diamond
Fortec LIFETIME
Fortec Lifetime ULTRA
Fortec Lifetime Ultra Diamond
Fortec MAGIC
Fortec Ultimate
Lava 3200
Megasat (All)
Neosat iPro1000 (or Ethernet)
Neusat SP6000 (& USB Mem Stick)
Pansat 1500 and all Clones
Pansat 2300a and all Clones
Pansat 2500a and all clones
Pantec/Multistar MS (All except MS1000)
Pantec MX/Ultra
Skyview 500
Smartwave 2500A-N2
Smartwave 2700A-N2
Traxis DBS 1500
Traxis DBS 2500
Traxis DBS 3500
Traxis DBS 4500
Traxis DBS 4550
Trimax T100
USB Update Support
Viewsat Ultra
Conaxsat CNX-V1
Neusat SP6000
Pansat 5000HC
Pansat 6000HCX PVR
SonicView SV1000PVR
Sonicview SV-4000
Username: Dude123
Post Number: 941
There is a difference between the two cables, take a closer look!!!!
Username: Lklives
Post Number: 7906
Ocassionally the dealer will send the wrong cable with the receiver..
BTW...the post above by bruce is a copy/paste of a post by McSunny that is ACTIVELY shown kere already!!!!...people can usually get their answers if they just look at the thread SUBJECTS and READ first, and NOT just post questions in the first thread they see!
Username: Brucester
Post Number: 312
thanks for pointing that out lk but i did say i got it 20 or 25 post down im just tring to help have a nice day all
Username: Rtap
MIAMI, FL MIAMI
Post Number: 56
bruce I i did read the other thread explaining this subject but my question is how do i program both the 2500 and the 3500 with the null cable
Username: Brucester
Post Number: 313
rtap ill go see if i can get info for you on that i have clone 2500 and i have cw600p i have 1 cable for cw it is null and my pansat stright throught but i did not like changing the cable so bought an adapter witch changis it back from null to stright works good on my boxes
Username: Brucester
Post Number: 314
the adapter is the best way to go i think found some info at this site dssrookie*com or the home of pansat future-fta*info chang the star to a dot hope this helps
Username: Lklives
Post Number: 7914
The Pansat 2500 (straight cable) and 3500 (null cable) use different cables BUT radio shack sells a cheap adapter that when added to the straight cable it converts it to a null modem cable..
Want to know what cable you need to flash that shiny,new receiver ? There are two types of cables used, and both look the same on the outside, but are wired differently internally. They are the straight DB9 RS232 female to female cable, and the Null 9 pin RS232 female to female cable. The straight DB9 cable has all pins connected the same at both ends(pin 1-1, 2-2,3-3,etc.). The Null cable(also known as a Null-Modem) has pins 2 and 3 crossed(pin 2-3, 3-2). You can use a straight DB9 cable to program receivers requiring a Null cable, by purchasing an inexpensive Null adapter to attach to one end of the straight DB9 cable. This allows one cable to be used for any receiver.
Username: Lklives
Post Number: 7922
Username: Brucester
Post Number: 316
lol i think he must of read that by now on other site
Username: Lklives
Post Number: 7925
Since he specifically asked me, I figured I could at least give him a good reply!...and I have NO clue if he's already read anything!
Username: Brucester
Post Number: 317
ok have a good night im bored lol
Username: Nikk
Post Number: 1364
Another thing.....
I was the one who originally posted those images related to the cable configuration....at that time there was a mistake on the null modem image, if you can see it says Female to Male...
The right one is Female to Female....that was corrected a couple of weeks after the first publication......
Username: Brucester
Post Number: 319
nikk mty thanks for the heads up on that have a nice day keep up the good work
Username: Rtap
MIAMI, FL MIAMI
Post Number: 60
thanks for not bashing me
