CW600PV1.37 Cw100R support 02-22-2007
Username: Brucester
Post Number: 321
CW-100R support for schedule recording through EPG menu.
-Connect the CW-100R DVB recorder to your captiveworks receiver through Straight serial cable
-go to EPG
-select any show that you want to record
-click green button and confirm.
-when the time comes, the CW-100R will start record automaticly and when the time finishes it will stop recording
With the CW-100R you can also load bin file to the receiver.
-get whatever the latest file is and save it on a memory stick or SD card.
-rename the file to "SETUPBOX.BIN"
-put receiver on standby
-go to the Play file in the recorder menu and find your file and click OK.
The CW-100R will record the videos in Mpeg4 format, and you can play it back on the TV or on your pc. You can also play other Mpeg4 files that you download from online on your TV.
Many new features will be introduced on the CW100-R and it will work side by side with the captiveworks models. keep up the good work cw and team
