Component Video Help
Username: Cflip2x
Hilside, NJ United States
Need some help. I just purchased a ATLONA COMPONENT VIDEO SWITCH and connected everything to one of my component ports on the back of my TV so that I can have both my Xbox and DVD playe on the ports that support 480P, 720P, 1080I Everything was fine before I had the switch. Though now I am getting a green tint. I have tried switching the cables with ones that I know to work but my xbox and dvd player both have the tint. Also It appears to have some static when i set the sharpness to my TV to a higher setting I was wondering if anyone has had similar problems.
Username: Matt_whitlock
Post Number: 14
I've found several HD component switches that seriously alter the image quality... at any resolution.
There are some switches out there that do work well though. I've been using the Psyclone PSC01 for about 3 months now, and can tell you it works flawlessly.
http://www.psyclonecables.com/products/index.asp?con=source&id=990
Good Luck!
Matt Whitlock - Editor, TechLore.com
