Pantec2500 MS ultra....288T & 289T
Username: Hockeys_back
Post Number: 39
can't get the 288t or the 289t to work, keeps saying "wait for picture".....the 289t did work for 10 minutes, but then it went down "wait for picture" .....ar is off, and i put the keys in, and nothing works
Username: Destine0429
Quebec Canada
Post Number: 95
hey, you need to turn the autoroll off. Go into Menu, then to Parental Control, second Pin enter 0000, then go down to Autoroll and click ok, go to DN and BEV and turn the AUTOROLL off.
Username: Prfrmnj
Post Number: 1878
Key changed. Turn autoroll off as instructed by Julie and manually imput keys.
Post Number: 40
did that when i installed the bin, and like i said it worked for 10 min's then stop working, Ar is off, and the keys are the active one's right now...
Username: Vndpatel
Post Number: 121
are all the sites down or something every time i try to go on they say The page cannot be displayed. the only one that works is dsscommunity.
Username: Nydas
Post Number: 1660
Hockeys_back : Did you set the time, date and tiem zone? Sometimes it freezes trying to load the EPG.
Also try "set default Keys" and enter both keys afresh manually after this and then switch off/on
