289T doesn't fix scrambled/bad channel issue
Username: Crazy416
Post Number: 31
As the title says it, i was having this problem with the 288t bin and thought the new one would fix it, but the only thing it fixes is the slow channel change and freezing problems. btw, im talking about bev here, and don't know about dish yet.
Username: Costarican
Try the 289T Bin, it seems to work for many people.
Username: Crazy416
Post Number: 32
I have 289T bin, and it doesn't fix the scrambled/bad channel problem just like the previous bin. i think it might be working fine for those with DN, but im talking about BEV here and the problem is still there.
Username: Mc_sunny
Post Number: 1034
dani, it is working fine for bev as well....do u have ur AutoROll ON ???? Leave ur AutoRoll on and put on any channel and wait until u get picture
Username: Brucester
Post Number: 188
that bin 289 and 288 have there problums so fare after 25 min my box gos off on off on till i get up and turn it off by the back of the box and it will work for 25 min and do it all over off on but get all channels but plaboy on my lava3200 clone of pansat2500 dos any one having this problum thanks have nice day all
Username: Brucester
Post Number: 189
im on bev nimq1 all channels are good but plaboy
Username: Zibruno
Post Number: 16
hey bruce where did you get 289t bin
Username: Mc_sunny
Post Number: 1035
289T safe for clones!
Thank's to chancysand
Moded for Hughes / Tivo ir codes. Good for ALL !
Enjoy !
Good for all" means, all of the Pansat 2500a and Fortec Ultra and clones.
Use BL uploader.
1. Default, kill all settings, including channel lists.
2. Flash current bin/file
3. Set up antenna settings, switch/ports
4. Scan All per sat. DO NOT BLINDSCAN.
5. Turn OFF AutoTp,
6. Turn ON< AutoRoll
7. Set time, clock and date, correctly for the EPG to work
8. Select E, Package, select channel, WAIT for video, do not change channels
9. For N, sort by alphabet, select channel, wait for video.
Click
here...http://www.tryfta.com/showthread.php?t=1385
Username: Brucester
Post Number: 190
i got my bin from this sit Chancysand's X-85BL_070125_289T_db_api(N).bin
"Good for all" means, all of the Pansat 2500a and Fortec Ultra and clones.
Enjoy !
Special Thanks to JVVH for the help on this one.
http://www.dssevolution.com/forums/s...906#post567906
Username: Crazy416
Post Number: 33
Mc Sunny, i have the autoroll on, i have channels like ary, b4u, ndtv, cbn working with no problem, but getting only scrambled/bad channel issue with other channels like tsn and ppvs.
after reading ur post, i decided to wait for a while on one of those channels to see if i'd get a picture, but to no avail. after a little while, "wait for picture" came up and it went up to 600% and then back to scrambled/bad channel.
Do you have all your nimiq 2 channels working?
Username: Letmeon
Post Number: 129
289t works fine........what kind of weather do U have? transmission is dependent on the cloud/rain/snow situation, also consider the signal is beamed up first, THEN down. Any weather can affect certain channles...
Username: Dishlover
Toronto, Ontario Canad
Post Number: 33
289t is not working good for me as well.After few ,minutes it freezes and receiver restarts again. Slow changing chanel and so on.
Username: Nestea
Post Number: 58
289T still have same problems. My receiver still switch off and on.
