Need help ASAP
Username: Andrewmenia911
Post Number: 58
i have a problem.. i have pansat 2700A with bin 288.. yesterday my dish 119 and 148 were working fine before i went to sleep.. today when i opend it it worked good for a while then it said no signal on all the channels.. i tried to close it from the back and open it again and it didn't help.. i even tried to unplug it from the electric and wait and then plug it back and still it didn't make any difference.. any help plz
Username: Senators
Post Number: 56
check dish and make sure it point right
check ur keys make sure it up to date
check all cable and stuff
Username: Gocuse3
Post Number: 19
I HAVE THE LASTEST KEYS FOR DISH
I HAVE A GOOD SIGNAL STRENGTH
CABLES ARE GOOD
ANY OTHER IDEALS
Username: Gastrognome
tony, your viewsat may need the latest bin 061213x
Username: Mrred3706
Sounds like J-tag time! Don't feel bad...same for me.
Post Number: 59
well thankssssss so much wing.. in the past days the weather was so bad that the wires got untied some how.. and so when i tied them right back they all worked fine with me.. i suggest to all to check their wires before searching for new keys..
Username: Lklives
Post Number: 6332
1st thing U always do is a receiver REBOOT (rear switch or Unplug)
2nd... recheck antenna/dish settings in receiver
3rd...check keys
4th.... check cables and connections
Username: 1irambo
Post Number: 39
LK put newest bin. I must have inadvertantly changed setting somewhere. 2700a dish 500 twin. Can not get 119. Think I changed diseqc. I have single rg6 to stb. Any suggestions?
Username: Lklives
Post Number: 6340
EY..do NOT double post same thing everywhere here...U will get NO help like that!
Username: Gocuse3
Post Number: 20
lk
i did the reboot, i checked the antenna and dish settings, just a begiiner what should i look for when i do that, the keys are still good and the connections are still good
thanks again,
do you think i need the new bin
Username: Lklives
Post Number: 6378
I think U need to use a Reputable DSS site that has files, guides and manuals, and begin to READ!
Username: 3500new
on Indian channels, I get all except ZEE, B4U and ZEE cine.
Can anyone help me to uncover these hidden channels ?
thanks
Username: Nydas
Post Number: 1046
Ram: Many people in Toronto area have had these sporadic loss of ZEE,B4U and Zee cine.
Make sure you have your clock and time zone correct.
Do a "set default keys"
Turn autoroll off
Enter Nagravision 2 keys manually
Switch off
Switch on
If you have English channels on 110 or 119, go for those till you get a good picture. Then go back to your 61.5 and very often, the problem will have corrected itself.
Blind scan again if necessary.
The cause: If your receiver is off and during that time there are 2-3 key changes, you may have these kinds of problem. If your clock is wrong (some receivers don't keep time when turned off) you get problems.
I said Toronto earlier to be precise about source of my info. It probably applies to other areas.
The least likely cause is the dish moving, so don't start fiddling with that in the cold weather.
