How To Get Indian Channel DishNet
Username: Mc_sunny
Post Number: 791
Here is a Easy Steps To get Indian Channels.
First if you allready have dishnet Reciever Installed go to
Menu-->6-->1-->1 and see what signal you are getting
it could be
61.5 WEST ,
121 WEST (IF YOU HAVE BIG SUPERDISH)
OR
148 WEST
IF YOU HAVE 119 OR 110 WEST ONLY YOU WILL NOT GET ANY INDIAN CHANNELS.
After you find out which one of this signal you have, it will be easy for you to install your pansat or any other reciever you have.
IF YOU HAVE PANSAT MOST OF PANSAT MODELS HAVE SAME SETTINGS
ON YOUR PANSAT
1)GO TO MENU
2)INSTALLATION
3) ANTENNA SETUP
4) HERE YOU WILL HAVE TO SELECT ONE FROM 3 SATELLITE.
1-61.5°W EchoStar 3
2-121.0°W EchoStar 9
3-148.0°W EchoStar 1/2
5) IF YOU HAVE 61.5 OR 148 YOU WILL HAVE SAME SETTING FOR BOTH
6)
LNB TYPE - STANDRED
LNB FREQ - 11250
22KHZ - OFF
DISEQC - DEPENDS OF YOU HAVE SWITCH INSTALLED 1 2 3 OR 4
SKEW - DON'T MESS WITH IT
TP - DON'T MESS WITH IT
POSITI SET - Disable
Satellite Scan - ALL
7) LEVEL IS YOUR NOT YOUR SIGNAL IF YOU DON'T GET LEVEL YOU WON'T GET QUALITY
8) QUALITY IS YOUR SIGNAL FROM DISH- THIS MUST BE OVER 70% MEANS GOOD SIGNAL
9) EXIT AND SAVE
10) FINALLY GO TO SAT SCAN AND SELECT ECHO 3 OR 1.2 AND SCAN THE SAT.
SCANNING WILL TAKE SOME THING SO LET SCAN TILL 100%
FOR 121
JUST LNB FREQ YOU DON'T HAVE TO CHANGE TO ANY THING
LEAVE IT TO 10750
AND FOLLOW SAME STEPS AS ABOVE
GOOD LUCK
ENJOY
Username: Ars88
Post Number: 69
nice post mcsunny thanks but i gotta ques tho its for echo 8.10 im missing the ppv channel..i thought it was the lnb freq and when i changed it and did blindscan i got more channels but still no ppv lol what can be the prob here?
Username: Ars88
Post Number: 70
sry i didn't intend to hijack thread lol
Username: Mc_sunny
Post Number: 820
Arslan which ppv channels are u getting ? write down the channel numbers...and how many Satellite u have ??
Username: Ars88
Post Number: 72
i have echo 3 (61.5) echo 7/8.10(110)
and its just 2 ppv channels not sure of channel number didnt have time to check yet but will let u kno i also some VOD (video on demand?) which also showing some movies but thats also about 2-4 channels
Username: Mc_sunny
Post Number: 875
Arslan most of ppv channels moved to 110,...just do factory default then rescan,When you are going to scan bird 119 make sure your tp frequency is adjusted to 12239 if its not adjusted to this before you scan you will miss tons of channels,dealers are sometimes forgetting to inform there customers of this and alot of confusion can result!
119=TP Freq-12239
110=TP Freq-12224
91=TP Freq-12224
EchoStar 7 - 119. ECHO 7
LNB Power------ON
LNB Type-------Standard For dish pro set to OCS
LNB Freq-----------11250
22kHz-------------Off unless you have a 22kHz switch turn on.
TP Freq----------12239
Search option-----All
DiSEqC 1.0------Port 1
Motor--------------Off
Legacy SW------None
Username: Sitsat
Post Number: 63
Thanks very much for the post Mc Sunny but on Echo 7/119, I just did a scan on TP-12239 and it didn't pick any channels on both H and V. Am I doing something wrong? Iam not getting channel 500 on echostar package since yesterday. Is that on TP 12239?
Username: Mc_sunny
Post Number: 876
For channel 500 try Doing tp scan #16 at 119°
Username: Mc_sunny
Post Number: 891
Sitsat those channels are gone at this moment..
Username: Playa_zihua
Post Number: 41
mc sunny do i go to factory setting then rescan
Username: Crippledwarcook
Post Number: 126
We don't care how to get Indian channels...they are nothing but fcuking towel heads who reek of curry...totally disgusting...and I also think they like to have sexx with their cousins...ROTF
Username: Big_fat_j
POTTSVILLE, STONEYTOWN GREEN-LAND
Post Number: 252
CAMELS NOT COUSINS.OH WAIT,THERE COUSINS ARE CAMELS.
Username: Dry_dent_lure
Wow! You two are really funny. Do you have a team of comedy writers working for you? What a couple of tards.
