Viewsat extrems new keys bev
Username: Chase_19
Hi,
Can someone please explain to me how I update the keys manually (bev) for my viewsat extreme.
Thanks!
Username: Martinpraguer
Bohemia
Post Number: 25
Chase, can't help 100% with Bev, I had not time to install it. But this should help:
1) Press: 'Menu'
2) Select '5-Options'
3) Change 'Auto Roll' from 'On' to 'Off'
4) Press 'Exit'
5) Select '3-Installation' (If asked to enter pin try '0000', this is the default pin)
6) Select '7-Code'
7) Select '3-Nagra'
8) Press the Left arrow until You see DISH 01 01 00 - next one would be "BEV" I am not sure, but there maybe 2 "Bev"s (There to "Dish"s), make sure you are in the right one.
9) Press the down arrow to edit the Keys
(1st line-00 is not part of the keys-this applies to "Dish").
Key Numbers-16 Pairs of numbers.
"A/B/C/D"="F1/F2/F3/F4"
For entering Keys "E" = "return" (Above the + Button).
"F" button is the "Text" or "Color" button.
Cheers
