Pansat 2700A problem
Username: Drm035
Darlington, SC USA
Post Number: 43
I am trying to download the 288 into the pansat 2700 but I keep getting a Flash Update Fail. what does this mean and what can I do. Thanks
Username: Nikk
Post Number: 677
Which kind of cable are you using to download???, you must use a null modem cable, also you need to check if the serial port on your computer is not being used by another application like palm hotsync or any other handheld sync device....
Username: Drm035
Darlington, SC USA
Post Number: 44
I am using the right cable, I just programmed a Cools*t. It is only the pansat that is messing up.
Username: Nikk
Post Number: 678
Which model of Cools*t did you downloaded???
Check this and you will know if you have the right cable...
*Cools*t 4000 Plus-Null modem cable
*Cools*t 4000 Pro. 5000 & 6000-Straight through DB9
Username: Dude123
Post Number: 756
Receivers that take a Null Modem Cable
Ariza Ultra 400/500/700/Extreme
Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II, MS1000, ,etc.)
Cools*at 4000 Plus
Cooltec
Coship (All)
Digiwave 6800/7000
Dreambox (All)
Lava 2600
Max 2500
Microroyal (All)
Orasat (All)
Pansat 2700
Pansat 3500
Pansat 5000HC(Also can program through USB)
Pantec/Multistar Max (All)
Rex1
Silver bullet/ST 1000/2000
Spacestar DVB500
Stealth 2000a
Techsat
Ultrastar 5000
Viewsat VS2000 Platinum
Viewsat VS2000 xtreme (extreme)
Receivers that Take a Straight Through Cable
Astrovox 2600
Cools*at 4000 Pro
Cools*at 5000 Platinum
Cools*at 6000 Premium
Digiwave Diamond
Extremeview
Fortec lifetime
Fortec Lifetime Ultra
Pansat 2300a/2500a and all clones
Pantec/Multistar MS (All except MS1000)
Pantec MX/Ultra
Skyview 500
Username: Drm035
Darlington, SC USA
Post Number: 45
I am trying to program the Pansat 2700. I am using the right cable. Everything fits, it just keeps giving me that error.
Username: Nikk
Post Number: 684
Becky...
That error happens when the communication between the PC and the receiver can not be established, and it is normally due to a wrong cable or a wrong com port configuration, at this point I would recommend you to get the Pansat 3.38 loader from pansatusa.com and try to download using that one.
You said you are sure about using the right cable...have you downloaded a bin to that Pansat before using that cable you are trying to use now???....
Username: Drm035
Darlington, SC USA
Post Number: 46
I have used this cable to program a Pansat 2500, a Cools*t, and have programmed the Pansat 2700 with it a while back. When I couldn't get it to program earlier I went ahead and hooked up the Cools*t and it worked fine.
Username: Nikk
Post Number: 685
I know you are trying to program the 2700, but you said you already programmed a _Coolsat using that cable, the thing is that depending on the model of _Coolsat that you programmed the cable varies, that's why I put the description of the cables for the _Coolsat, which model of _Coolsat you downloaded with that cable???
Username: Nikk
Post Number: 686
How could you program a 2500 and the 2700 with that cable???.. 2500 uses a RS232 Straight, and 2700 uses a RS232 Null Modem, you can not program both receivers with the same cable unless you plug an adapter to convert RS232 Straight to Null Modem or Viceversa....it is impossible to program both receivers without using an adapter...
Username: Drm035
Darlington, SC USA
Post Number: 47
4000 pro. I programmed this same pansat box a months ago, they did not bring it to me to program the new fix in it until now. I have used the same type of cable on it the RS 232 cable
Username: Nikk
Post Number: 687
Pansat 2700 uses RS232 Null Modem Cable
Pansat 2500 uses RS232 Straight Cable
_Coolsat 4000 Plus uses RS232 Null Modem Cable
_Coolsat 4000 Pro uses RS232 Straight Cable
_Coolsat 5000 Platinum uses RS232 Straight Cable
_Coolsat 6000 Premium uses RS232 Straight Cable
Username: Nikk
Post Number: 688
The thing is that to program a 4000 Pro and a Pansat 2500 you use the same cable, but to program a Pansat 2700 you need a different kind of cable...
Username: Nikk
Post Number: 689
Both cables are RS232 but change on teh way the pins are connected through, RS232 Straight have the pins cabled 1 to 1 and RS232 Null Modem have the pins 2&3 crossed on each side of the cable...
Username: Drm035
Darlington, SC USA
Post Number: 48
I have looked at the back of all the boxes the ports are the same. The cable fits fine. I just cant get the program to download
Username: Nikk
Post Number: 694
It is not matter about if the cable fits....the connector is the same, the thing that change is the internal configuration of the cable......
Username: Nikk
Post Number: 695
The port at the back is DB9 for all of them, the internal cable configuration is the one that changes, that makes the difference, when I say that uses a different cable I don not mean that the cable has a different kind of connector, on the outside the connector is the same for all of the cables, but inside the cable they are wired different......
Username: Nikk
Post Number: 696
Username: Drm035
Darlington, SC USA
Post Number: 49
went to radioshack and the guy gave me the null modem and it still is not working
Username: Drm035
Darlington, SC USA
Post Number: 51
Thanks for all the help, it finally started working.
Username: Nikk
Post Number: 698
Becky...what you made different from what you were doing??
Username: Grub
Post Number: 7
thats great help.....although ididnt post but info was perfect
thks
