Serial cable help
Username: Happytv
hello,
I am trying to connect my pansat 3500 to my laptop so I can upload the bin file, however the pansat is a 9 pin male and my laptop is a 15 pin female. Is there a cable i can use to directly connect these devices? I have a 9 pin female to 9 pin female cable. Maybe I can use a converter? I also have the 9 pin male to usb which proved to be useless. Can someone tell me what I can do.
Username: Bogus
TO
Post Number: 15
Tom that 15 pin conn is most likely a VGA output.
you most likely have USB ports. Get a USB to serial adapter avail at any computer outlet
Username: Bogus
TO
Post Number: 16
BTW i never had any luck with the IBM USB to serial adapter that came with the laptop iam using some no=name adapter and it's flawless
Username: Happytv
Thanks bogus, I thought you have to use serial not usb. I tried the usb to serial, however i tried the com 3 port (the only one that worked) in the loader and it just idles, it doesnt go past 0%
Username: Asharfi
Post Number: 355
Guys,
Here's the list of receivers with their serial cables. Please save this and don't ask questions about serial cables again!
List of receivers with what kind of serial cable they need:
Ariza Ultra 400/500/700- Null
Astrovox 2600-Straight DB9
Blackbird and all Blackbird clones(BOB, Max 1000, Stealth II, MS1000, ,etc.)-Null
C00lsat 4000 Plus-Null
C00lsat 4000 Pro-Straight DB9
Cooltec-Sraight DB9
Coship (All)-Null
Digiwave 6800/7000-Null
Digiwave Diamond-Straight DB9
Dreambox (All)-Null
Fortec lifetime-Straight DB9
Fortec Lifetime Ultra-Straight DB9
Lava 2600-Null
Max 2500-Null
Megasat (All)-Straight DB9
Microroyal (All)-Null
Pansat 2300a/2500a and clones-Straight DB9
Pansat 2700/3500 -Null
Pansat 5000HC-Null(Also can program through USB)
Pantec/Multistar Max (All)-Null
Pantec/Multistar MS (All except MS1000)-Straight
Pantec MX/Ultra-Straight DB9
Rex1-Null
Silver bullet/ST 1000/2000-Null
Skyview 500-Straight DB9
Spacestar DVB500-null
Stealth 2000a-Null
Ultrastar 5000-Null
Viewsat VS2000-Null
I got this from LK, don't forget to say "Thanks" to him. LK posted this 2.5 months ago and I copied and saved it into my computer.
