Viewsat xtreme how to put in keys
Username: Tinytunes
Post Number: 14
Can some help me with my viewsat xtreme to put the keys in it i had went down so did my pansat 3000. Thank you.
Username: Lklives
Post Number: 5752
LOOK and READ...that has been answered here at least 1000 times!...use the SEARCH tool!
Username: Mvr
Post Number: 20
LK!
Is there a new BIN for viewsat xtreme?.All my channels went down at 6 p.m today.Please help
Username: Lklives
Post Number: 5753
no...just a simple key change
Username: Chrissymegan
Post Number: 8
I tried the new keychange. can you list how to enter new keys? i mean what will go in 08: 09: 88: and 89: section?
Username: Lklives
Post Number: 5756
key0 in 08 and 09
key 01 in 88 and 89
Username: Prfrmnj
Post Number: 853
How To Manually Enter Keys
1. Press Menu Button
2. Installation Selection ( #3 )
3. Code Selection ( #7 )
4. Nagra Selection ( #3 )
5. Dish Network
6. Always Leave The First Set Of Digits Alone (08 & 09 first set and 88 & 89 second set). A Total Of 16 Digits for each set of keys
7. Press Exit And Press Ok To Save Changes
8. Press Exit Button To Completely Exit Out Of Menu Options To Watch Tv .
Username: Lklives
Post Number: 5757
CAS Line Code Info
Coo*lsat: KEY Line 10 and 11 are for Idea Key 0 and Line 20 and 21 are for Idea Key 1
Pansat: key 00 for Idea Key 0 and Key 01 for Idea key 1
Viewsat: line 08 and 09 for Idea Key 0 and lines 88 and 89 for Idea key 1
For Receivers with only two Key Lines, Enter Active Idea Key into 00 and 01
Post Number: 10
wow! i verified the keys 5 times, entered with autoroll off, crippled and others please explain me how to make it work on my viewsat. Please!!!!!!
Thanks in advance.
Username: Lklives
Post Number: 5758
we can't make it any simpler than this...follow the simple directions..TY ryerson
Username: Prfrmnj
Post Number: 855
Chrissy - I posted the instructions on how to imput keys. Pay close attention to the note. Do not mess with the first two digits. Also verify that you entered the keys in the correct spot. Some Viewsats have two (2) dishnet providers ID in the setup. One is a fake, make sure you enter the keys in both!
Username: Crippledwarcook
Post Number: 107
LOL...where did you find a picture of that fcuking retard fred...he's having such a hard time getting his machine going...he needs to tell his boyfriend to quit ballsucking him until he is done fixing his machine...ROTF
Post Number: 13
PERFRMNJ
I have only one dishnet provider page with no 00 keys i have four rows 08, 09, 88, and 89. I did exactly as per your page. no luck man!
Username: Prfrmnj
Post Number: 858
LMAO! Great Picture!
Username: Prfrmnj
Post Number: 859
Verify your keys again and cycle through all the providers. Do not change the first set. If you changed the first set you will need to go back and fix everything.
Username: Martinpraguer
Bohemia
Viewsat Extreme
Try this: I did not have to change Autoroll in this case (skip #2,3,4 below), just change the keys.
1) Press: 'Menu'
2) Select '5-Options'
3) Change 'Auto Roll' from 'On' to 'Off'
4) Press 'Exit'
5) Select '3-Installation' (If asked to enter pin try '0000', this is the default pin)
6) Select '7-Code'
7) Select '3-Nagra'
8) Press the Left arrow until You see DISH 01 01 00 (in my case it says "UNKOWN" - next one would be "BEV", there are 2 "DISH" - 01 01 00 or 00 01 00).So make sure you are in the right one.
There are 5 rows of numbers
9) Press the down arrow to edit the Keys
1st line-00 is not part of the keys.
Line 08 and 09 are the 00 Keys.
The 08 and 09 Numbers are not part of the Keys so don't change them.
Key code starts after the 08 and 09 Numbers-16 Pairs of numbers.
Line 88 and 89 are the 01 Keys.
Again 88 and 89 Numbers are not part of the Keys, so don't change them.
The 01 Key code is entered after the 88 and 89 Numbers----16 Pairs of numbers.
See Chris Rucchin above for exact detail.
And see you manual for remote control to find where is your ABCDE keys on remote keypad.
Cheers
Post Number: 15
WORKING!!!!!!!!!!!! thanks.... there were two entries.
Username: Mrcharley
Port norris, N.j. U.s.a.
Post Number: 76
why go through all of that when all you had to do is load the newest opkey
application/octet-streamUpload
11-20-2006_opkey.hex (65.5 k)
