Viewsat extreme help
Username: Schifty
Post Number: 23
My dishnet went down tonight checked keys in key ripper and changed them but still no picture lots of signal strength. checked keys three times installed correctly according to key ripper. anyone else having a problem if there is one working what are your keys thanks
Username: Tinytunes
Post Number: 15
Yes i just got a viewsat X and i am down can you let me no how to put the new keys in Thank you.
Username: Chrissymegan
Post Number: 7
John,
Is your viewsat extreme working with new codes?
Username: Mvr
Post Number: 22
i too have viewsat xtreme and mine too went down.Is there a new bin or just enter keys?.Please help
Username: Crippledwarcook
Post Number: 100
Enter the keys you dumb fcuking retards...it's not rocket science..turn off autoroll and manually enter keys..my fcuking 8yr old could do it...fruitcakes..ROTF
Username: Schifty
Post Number: 24
just checked keys again and had one wrong on third line i had 08 instead of ob really hard to tell them apart on keyripper all working again
thanks guys my mistake
Username: Fredster
Post Number: 19
Crippled ...you're the moron .... it doesn't work ...
Post Number: 103
hey fred...do you have cloth hanger marks on your head?..or are you just fcuking naturally retarded...just enter the keys you fcuking twinkie..ROTF
Username: Schifty
Post Number: 25
that guy is a moron I changed keys properly and all working
Username: Runnerguy
Pluto
Post Number: 48
CWC is not moron!!...It takes a little time to warm-up to hims.
