24 hour Tv guide
Username: Charjam
Post Number: 82
Is there any TV guides that i could download that has more than a 2 hr. tv guide THANKS
Username: Ryersonresurrected
Internationa...
Post Number: 222
Do u mean an EPG, or are u talking about a site to see which shows are o?
For the latter, dishnet u will have 2 select "all channels"
http://***.dishnetwork.com/content/programming/programming_guides/index.shtml
Try this one for BEv:
http://***.bell.ca/ExpressVuEPG/loadVuGuide.do?lang=en
* Replace the *** with www
Username: Charjam
Post Number: 83
Thanks Ryerson but i was looking for something like the EPG but goes farther than 1-2 hours. There must be something out there . I looked at dss tester and they have a lot but it doesn't say anything about how long it is Thanks for the reply
Username: Shenanigans
Post Number: 40
I've been using titantv.com for several years. Gotta admit, I've been pretty happy with it. You can customize the guide to use it however your channels are listed in your receiver. It's possible to add practically any channel you want. This includes many of the bev channels as well. Before dn went to using so many spot beams for locals, I had over 1200 channels set up in mine.
You can search stations by call letters or (for non over air) station IDs. Once you've found the station you want, just click to add it to the list. You can get info for up to 14 days in advance.
Username: Charjam
Post Number: 84
Thanks Shenanigans i went there , That is pretty good i will use that until something better comes up Thanks
Username: Lklives
Post Number: 5205
That has been considered the best by many for years!...good post Shenaningan
Username: Birdwatcher
Post Number: 498
Do you have to put your two cents in for everything LK (likes Kids) is that how you got to be a gold member.
Username: Dude123
Post Number: 465
Yep!! without his rudeness no forum is a forum!!!
Post Number: 500
yeah him and his little band of je.rks think they are the hottest thing around here. they are not showing anything that has not been said before. If some people would just read a little, they would find the answer.
CANADA Charlatan...
Post Number: 228
CANADA Charlatan...
Post Number: 229
Username: Minn_rock
Post Number: 594
BIRDBOY U R 1 UGLY M.F..
MY BIRDBOY...
CANADA Charlatan...
Post Number: 234
This is the result of vandiesel fornicating with his dog - enjoy ur son/puppy, birdman! LMAO!!
Username: Jenifer_contreras
PIMP Member, Yokosuka, Ka...
Post Number: 535
Why nobody invite me to the party ?
Post Number: 536
David Hunter ...try www Titan Tv dot com
Post Number: 538
yea..it's http://ww1.titantv.com/
Username: Minn_rock
Post Number: 596
JEN..i just got my viewsat extreme today ,and how u change the dam keys..lol..would u be a good girl post step by step for me pretty plz..
Post Number: 539
Go to my web, but Registration required,it's free!
Username: Minn_rock
Post Number: 597
LOL..u want to trick me into your web site to register,and found out my pc id#, and where i live,and u gona come and get me..NO WAY..........
just kidding i will..Thanks BABE...
Post Number: 540
I knew it,I knew...you will say that( about IP ),
BTW.check my "pc section" , there is alot interesting programs...
