New 283T autorolls FIX .Fortec Ultra & clones ...
Username: Biverland
Post Number: 44
283T from chancysand safe for Fortec Ultra & OLL ..
Tested autoroll dish & bell okUpload
Username: Lklives
Post Number: 5011
Pansat has all new bins that fixed the autoroll problem for ALL pansat receivers...and also chancysand has released a new Pansat 2500 Clone safe and fortec Ultra bin (283T)which are posted in the Pansat files area at www.dscommunity.c*om/forums
Username: Vc15
any thing for pansat2500 clones
Username: Lklives
Post Number: 5014
can U read"!...look above U!...thats sad and scary!
Username: Vc15
Post Number: 7
www.dscommunity.com/forums is down
Username: Lklives
Post Number: 5018
my mistake..www.dsscommunity.c*om/forums (remove the * in link and register for free)...my typo and apologies..
Username: Tutor
Post Number: 45
I downlaoded 283t for my FLU but i cant enter the old pin 0000
please help
Username: Lklives
Post Number: 5101
scan the channels sats first
Username: Tutor
Post Number: 47
Lk
my problem is that the 0000 pin does not work when I push the 0 button no thing happen
Username: Lklives
Post Number: 5104
upload the factory Fortec Ultra bin with an Fortec Ultra loader...scan the sats next...upload 283T bin with BL V 1 .4 updater or another Pansat uploader..
Username: Prfrmnj
Post Number: 686
FAH - What are you trying to do? I don't understand your question. I can only assume you are trying to go into parental controls, but if you have no channel data, it won't allow you to. Last but not least, why would you need to get into parental controls? That's only if you have to manually input keys, and the purpose of flashing 283t was for the autoroll...
Username: Tutor
Post Number: 48
it is my mistake I downlaoded 382 instead of 382t
now i'm trying to put the real bin 382t
Username: Tutor
Post Number: 49
now it is ok
Username: Lklives
Post Number: 5106
if U have a FLU (Fortec Lifetime Ultra)...U must use bin 283T...there is NO 382 bins..and if U load 283, U will kill your receiver most likely...then require a Jtag! and a $50 expense..
