Keep Losing Signal....Please help
Username: Babulal
Post Number: 27
I keep losing sat signal...I scan all channels, they come back and I am able to watch TV, but then after a few minutes, signal goes away...any ideas? I am using Fortec Ultra.
Thank you.
Username: Pjk
Post Number: 103
Maybe bad weather (wind, rain, etc...) or lnb on dish is loose...
Username: Nfl
Post Number: 76
yup...my 110 echo 8.6 loss signal due to bad weather. it's slightly off to start out with and plus bad weather it's completly out.
Username: Babulal
Post Number: 28
Thanks for the response, but weather is just fine...could it be the switch that I am using? I have 2 dishes, 110&119 (2 lnb) and 1 for 61.5. when the signal goes out, I get 'scrambled or bad channel'.
I am using bin 278T for Fotec Ultra...is there an updated one that you guys are using that works??
Username: Mc_sunny
Post Number: 421
Use the new bin for fortec ultra 280t...n.. make sure ur Antenna Setup are right
Username: Mc_sunny
Post Number: 422
This is latest Chancysand bin for Fortec ultra/Pansat clone safe
X-85BL_061003_280T_db_api(N) EPG Fix
http://www.dssevolution.com/forums/showthread.php?p=490907#post490907
Username: Babulal
Post Number: 30
Thanks Sunny. Should autoroll be off or on??
Username: Mc_sunny
Post Number: 424
After u done uploading the new bin
Go to parental control,Second pin enter code, scroll down to Autoroll option, click it open, go to Dishnet Autoroll, and turn off
1. Turn off auto Roll
2. go to key 01 in your key edit
3. the 5th set of keys on the top row change them to 70 then save.
These are the new keys for DN
Dish Network:
KEY00: 0C FA 39 73 91 5F F5 54 E9 56 1C 42 8B 7A CA B2 (Active)
KEY01: 66 B9 F6 53 70 ED 2A 5B 31 D5 59 D2 9F 1C 52 63
After u done all this u should have ur tv back..Good Luck
Username: Babulal
Post Number: 31
Great stuff Sunny!
Thanks.
