Bronze Member Username: KoooltecPost Number: 87 Registered: Jun-06 | hi all , i just got a maximum 2500 from a friend , i just wanted to know what bin do i put in it? a digiwave bin? and where can i find the loader? and is there a cardless fix for it? thanks |
Silver Member Username: JohnnerMiami, Florida Post Number: 721 Registered: Nov-05 |
Sounds like a clone of a Pansat 2500a http://www.dsscentral.net/files/uploads/X-85BL_060927_279T_db_api(N).zip |
Bronze Member Username: KoooltecPost Number: 88 Registered: Jun-06 | are you sure? i really dont want to burn my friends unit? because i check the reciever info from th menue , for some reason it said 307b3 , which is a Digiwave bin? | |
Silver Member Username: JohnnerMiami, Florida Post Number: 722 Registered: Nov-05 | Don't use 2500 bin, yes it will not work and I strongly believe the bin u need is the same one that is used on the MS100 or the Digiwave 7000. Also u will need a null modem cable...Check it out. Well read this i've never even hear about it! https://www.ecoustics.com/electronics/forum/home-video/274403.html |
