CAN I USE NEW VS FIX ON A VS CLONE
Username: Icekilla0388
Toronto, Ontario Canada
Post Number: 112
any1 know if i can use the new extreme fix n my extreme clone thanks
Username: Bobby29134
Post Number: 62
I think you can, you need to first use a special clone boot fix first then load the bin..
think ftabins.net has the clone boot fix under the pantec section..
gl
Post Number: 114
thank you,very helpful
Post Number: 116
hey i cant find the clone boot fix anywhere can some1 plz help
Post Number: 66
its there.. look under files > fta rec bins > pantec
hope this helps
Username: Timscarlet
Usa
Post Number: 229
viewsat clone fixes come right after viewsat fixes. please wait.
Post Number: 117
ok but i cant even load a file into my clone it just says 0000
