Channel list
Username: Aliplays
Post Number: 10
can anyone do a channel list to be downloaded cause My receiver has a problem and always restarts when the blind scan is done the only way to get channels is by downloading a channel list
Username: Evadelparaiso
Puerto Rico
Post Number: 2181
Alina for fix your problem run the latest bin again. The problem will be fix. For channel list go to dss tester com
Lucky
Username: Aliplays
Post Number: 11
Eva I have uploaded the bin a few times back in June and it would always reboot when I tried to scan it then I uploaded a channel list and that was the only way I could the channels to work cause I didn't have to do the blind acan. It always worked great till that day in June.
Never been able to do scan since June.
I wish you could help me fix this. Thanks
