Bronze Member Username: RikarddoPost Number: 65 Registered: Mar-06 | which are the working fta receivers except vs |
Silver Member Username: Da_bin_chi_codePost Number: 227 Registered: Jul-06 | 8/23/06--> Working: Viewsat PVR7000 8/22/06--> Working: Buzz S2010f Plus 8/22/06--> Working: Buzz S2010f 8/19/06--> Working: Sonicview SV1000 8/13/06--> Working: Viewsat Xtreme 8/13/06--> Working: Viewsat Platinum Temporary FTA fixes such as card sharing or emu are listed below. 8/17/06--> Working Temp Fix: ExtremeView Magnum (w/ "auxed" Rom102 in the card slot) [emu] 7/20/06--> Working Temp Fix: C00lsat 4000 (w/ "auxed" Rom102 in the card slot) [emu] 7/19/06--> Working Temp Fix: C00lsat 5000/6000 (w/ "auxed" Rom102 in the card slot) [emu] 7/15/06--> Working Temp Fix: SkyView RX600 (with card sharing only) [you have to supply your own cs server access] 7/14/06--> Working Temp Fix: CaptiveWorks CW-600S (with card sharing only) [you have to supply your own cs server access] 7/12/06--> Working Temp Fix: Neosat IPro 1000 (with card sharing only) 7/11/06--> Working Temp Fix: DVB PCI Card (with card sharing only) 7/10/06--> Working Temp Fix: CaptiveWorks CW-600 Premium (with card sharing only) [not a CW release] -need to do a server thru the DB and share that server with your CW Premium. 7/01/06--> Working Temp Fix: Triple Dragon (with card sharing only) 6/30/06--> Working Temp Fix: Dreambox (with card sharing only) |
Bronze Member Username: RikarddoPost Number: 66 Registered: Mar-06 | hey would i be able to what tv for free like using an fta receiver like ppv movies.... with this http://cgi.ebay.com/Twinhan-DTV-Sat-Card-Watch-TV-on-your-PC-102G_W0QQitemZ30002 1346229QQihZ020QQcategoryZ32846QQcmdZViewItem |
Bronze Member Username: RikarddoPost Number: 67 Registered: Mar-06 | which is the cheapest one from all of those and where can i get i saw some but they were expensive |
Silver Member Username: Jmill1948Chester, Va Usa Post Number: 974 Registered: Apr-04 | viewsat.........fleabay |
