Bronze Member Username: MrcharleyPort norris, N.j. U.s.a. Post Number: 14 Registered: Sep-05 | THIS PROGRAM WILL FIND YOU THE NEW KEYS SECONDS AFTER THEY CHANGE. SAW A LOT OF KEY BEGGERS IN AN EARLIER POST. THERE IS AN OLD ANCIENT SAYING. "GIVE ME THE KEYS AND I WILL WATCH FOR A DAY,TEACH ME TO GET THE KEYS AND I WILL WATCH FOR A LIFETIME" THAT IS YOUR LESSON FOR TODAY GRASSHOPPERS ENJOY
Silver Member Username: DjsmithCanada Post Number: 294 Registered: Jul-06 | got it but doesnt work after awhile and the keys for CyberDBS are missing last numbers . | |
Bronze Member Username: MrcharleyPort norris, N.j. U.s.a. Post Number: 16 Registered: Sep-05 | one of the 4 sites remaining will have the newest keys read the date of post and load the keys. has never let me down | |
Silver Member Username: DjsmithCanada Post Number: 304 Registered: Jul-06 | ok i downloaded your Zip .. i got an error Component "MSINNET.OCX' or one of its dependences not correctly registerd: a file is missing or invalid. NOW what Mrcharley ? |
Bronze Member Username: MickmPost Number: 32 Registered: Jul-06 | DJ: did you read the reamme file included in the zip? try that first | |
Bronze Member Username: MrcharleyPort norris, N.j. U.s.a. Post Number: 17 Registered: Sep-05 | the upload works i just tried it try rebooting your computer or just click on open instead of save and and use it that way | |
New member Username: Kt_alexPost Number: 1 Registered: Aug-06 | Thank you MrCharley for the file. It works great. Here is the tip. Read the READ ME.txt Unzip the file in 1 directory Run the .exe file Write down the name of the missing file Go to the Website that listed in the Read me.txt file and download the missing file. Unzip this file in the same directory that you unzip the earlier file from MrCharley. Then run... |
Silver Member Username: Jmill1948Chester, Va Usa Post Number: 909 Registered: Apr-04 | keyripper is another good program |
