102 card and C0olsat working perfect now for a wk.
Username: Waydown
Post Number: 201
you guys should get a co0lsat and card ,works good ,I get everything.
Username: Waydown
Post Number: 202
http://cgi.ebay.com/CO0LSAT-5000-PLATINUM-RECEIVER-OEM-X2-CARD-READER-B_W0QQitem Z300012509867QQihZ020QQcategoryZ32847QQrdZ1QQcmdZViewItem
change the 0 in co0lsat to o and the link will work
Username: Waydown
Post Number: 203
http://cgi.ebay.com/ROM-102-ACCESS-CARD-Rev-103-OPENED-and-UNLOCKED_W0QQitemZ250 014440795QQihZ015QQcategoryZ32843QQrdZ1QQcmdZViewItem
Username: Waydown
Post Number: 204
anyone that wants to get there Dn Back ,just Install bin #127 for the Co0lsat you have in a co0lsat 4000,5000,or 6000,and It will Aux the card for you, if the card is unlocked,about 300.00 dollars ,sell your veiwsat for 20.00 or just throw it away.this is less than a las Vegas Hooker.
Username: Alex_cheung
Post Number: 39
Thanks man for the usefull info.
Username: 2600
loop out from CS5k w/bin 127 to an unsubcribed DN reciever with card in it.no need for crd reader. presto!
Username: Waydown
Post Number: 205
I put a card reader in my CS4000,it was very easy,all cs recievers are built to put one in a factoy location, with a plug on the board.only 39.00
Username: Dicks_ndickweeds
Bonerland, USA Country Music
Post Number: 51
I take it the keys rolled. That f*ucking Ar*sehole penga can't even get that right and the V28H is f*ucking some cards.
