Yo what old bin works for Fortec ultra???
Username: Nassa
Post Number: 39
yeah same as questions (NO FLAMING)!!!!!
Username: Rsmc73
Post Number: 175
None!
Nassa just coming here is enough to get you flamed. Asking a Question will always get you flamed. Try DSS ROOKIE for help.
Username: Classified
YEAH GET OUT OF HERE NASSA
Username: Nassa
Post Number: 40
I DONT LIKE YOU CLASSIFIED YOUR A LOSER NO ONE LIKES YOU AND YOU SHOULD GO DIE!!~!!DDIE CLASSIFIED DIE!!!!!!!!!!!CLASSIFIED NO ONE LIKES YOU YOU SHOULD DIE!!!!!!DIE CLASSIFIED DIE!!!CAUSE NO ONE LIKES YOU DIE!!!!!GO CRAWL BACK INTO YOUR HOLE!!!DIE
ok......?????????KOOOKOOO
Username: Cooldude69
Post Number: 73
THERES LOTS OF IDIOTS OUT THERE MESSING WITH YOU GUYS! AS OF JULY 22, 2006 1:03AM THERE IS NO FIX!... PLEASE TRY TO NOT FALL FOR ANY OF THE STUPID POSTS SAYING THERES A FIX OR ELSE YOU WILL END UP HAVING TO JTAG, OR GET THE NIGHT RIDER......... HAVE PATIENCE AND WAIT, THERE WILL BE A FIX, IF YOU HAVE ANY DOUBTS JUST VISIT REPUTABLE SITES LIKE DSSCENTRAL OR DSSCOMMUNITY TO VERIFY IF ANY "NEW KEYS"...
Username: Iduknow
Post Number: 30
The vin ci code, 'cause there is no fix out yet.
Username: Bazuka2020
Post Number: 219
No bin working be careful specially with your fortec, it will fry and they charge sround $69 to fix it
Username: Iduknow
Post Number: 34
Old bins NFG.
