Help with bev???
Username: Armecab
Post Number: 7
For anyone out there who has sucessfully achieved Bev stats: where exactly do I input the active keys for Bev? I have done everything as per instructions : set default keys, factory setting, blind scanned etc. Now I guess the only thing left is to input the keys. The procedure is Menu - Parental Control - Second Pin and then what??? Do I enter the keys under NG2 and change Provider ID?? Please help???!!!!
Username: Fruitcakes
Post Number: 138
would help dumbazz if you told us what kind of reciever you have...duh!...ROTF
Username: Armecab
Post Number: 8
REceiver is Pansat 2500 clone....oops!
Post Number: 143
LOL...2500 clone...throw that piece of shiat in the garbage, you should of spent a few more bucks and got a good reciever...sorry, you have to watch cable..ROTF
Username: Nikkita
I so loved this forum. No need even TV, So funny.
Username: Amah
Post Number: 14
armecab.................I am new to this but I have the same reciever, u need to go into nagra 2 and change the ID provider until it says 0901 and then change the key which would be 00 or 01 and enter the rest of the keys in the 2 lines hit ok until it flashes and exit..............hope that works for u!!!!
