Please
Username: Osha
Hamilton, Ontario Canada
Post Number: 26
i have 2 dish outside and i have switch but i cant recive any signal in my reciver in the same time when i put my big dish 33' alone i can have a signal
Username: Bazuka2020
Post Number: 99
What kind of switch you have
Username: Osha
Post Number: 28
its DS4120P Multistar
Post Number: 100
I dont know what that is you need diseq switch, go to installation and select appropriate lnb for the dish and you will get the signal.
In installation you have to assign lnb for each dish
Username: Osha
Post Number: 29
how i do assign inb for dish
Post Number: 101
There are two cables coming from the dishes one from each, the switch has numbers for example dish towaqrds 110 sat cable going to No. 1 On the receiver you assign 1 to that sat and so on
Username: Osha
Post Number: 30
I dont know where i have to go to assign the dish i went to menue but nothing there i have viewsat2000
Post Number: 104
Installation
Username: Auburntigertim
Post Number: 15
click "MENU"; click "INSTALLATION"; click on "ANTENNA SETUP"; click on desired sat; scroll down to "DISEqC"....and enter either 1,2,3, or 4...whichever # that corresponds to that particular bird in your switch. Hope that helps
