A new bin for pansat is out.
Username: Zagros
Post Number: 30
http://www.dsstester*com/files.php?cat=14
Username: Rsmc73
Post Number: 133
you know you just crashed there site lol
Username: Vinidomine
Post Number: 114
all fake bins... please ignore!
Vini
Username: Hawaiian_time
Hawaii
Post Number: 162
Those bins killed receivers.
Post Number: 115
Zagros... people were posting negative comments on these fake been for the past 2+ hours over at DSSTESTER when you announced it here at eCoustics ... Did you even bother to read them?
ROTFLMAO - UN RE AL !
Vini
Post Number: 116
*been - bins
Username: Zagros
Post Number: 31
there are more than 400 donwloads and only one or to negative responds.
Username: Mimoune
Post Number: 10
guys dont trust the new bin is going to kill you reciever
Username: Zagros
Post Number: 32
Thanks guys, I was about to download the file but when I looked backed at the file I realised the it is much smaller than the bin 353, so it could be fake.
Username: Fatbastard
You know that when a bin is availablie...it will be all over the net...at reliable sites.....YOU KNOW THAT.
Username: Makemyday
Pansat 2500A.X-85BL.API : 2.78a_EU.Boot ver : .08. Jul. 2006
Username: Slowboy
Post Number: 13
My 2500 just want totally Blacked out..No more channels at all not even the radio..Black Sat..talk is cheap but hearing that in about a week maybe a fix????????? maybe bull who really knows..sad day in cal
Username: Rufa33
Post Number: 43
Listen to others guys. Don't burn your receivers. Wait and be patient. The good Bin's will be out soon or later. Those looks fake.
Username: Vkr95
Post Number: 7
can u give me the newest bin for pansat 3500s/sd? i tried the new fake bin got my reicver mest up but i fixed it. If u need help to get your system back to normal just ask. but please i need a new bin since i cant get 61.5 or 119. if theres a new key tell me that to.
Username: Zagros
Post Number: 33
No one can get them(61.5 and 119), we all need to wait.
Bin 353 is working for most channels of BEV. You can try that one. Also thanks for offering me your help, I did not download the fake bin.
Username: Nydas
Post Number: 98
The last VALID BINS are dated around 7th-10th June. Go to DSS*TESTER site or Future-FTA*info site for these and uploaders. Some channels will work with these BINs.
There are NO NEW BINS and NO NEW KEYS for the problems which started around 21st June, 2006. When the BINs are available, they will be posted. The latest valid keys are dated 24th May for DN and 7th June for BEV.
Please do not get carried away by false reports. Check and recheck authenticity of report before installing.
Username: Insanefor15mins
I'm new at this. what should I look for in a BIN file. Also when I last tried to download a file a message read "serial port: acsess denied" does that mean files is not good or should I check my settings?
Username: The_wank_artist
Post Number: 1284
Look for a bin that loves your box unconditionally. Doesn't try to fry it when it's not in a good mood. Treats it with respect and enjoys the time they spend together. (in short, one that was designed specifically for your receiver. If it's a clone, use a clone safe bin)
Yes, check your settings for the com port. Using a lap top? Make sure you have the correct port set up and that your drivers are updated.
