I need help
Username: Hcruz1_7706
Corpus christi, Tx Usa
i need help i want to get my computer to recognize my ports to port1 so i could get my laptop to recognize vortex pro 7700 to download the necessary information to get my channels to work on my receiver
Username: Concorde
Post Number: 11
What computer are you talking about.
What does your computer has to do with your laptop.
I think you are in the wrong forum body.
how culd i change my ports on my device manager to recognize port1, port2, port3 or port4 please help i cant figure it out
im sorry i mean my laptop
Username: Concorde
Post Number: 12
go to device mananger then
double click on Ports(COM&LPTP)
go to Comunications port(COM#)
go to Port settings
go to advance lower left corner choose port and whala thats for XP
Are you using a serial to usb cable?
can anyone help me please i need some help on getting my laptop to recognize my usb serial adapter so i could get my laptop to recognize the vortex pro 7700 so i could download the necessary information to get my channels to work
serial to usb
Username: Concorde
Post Number: 14
is that a yes ???
what laptop do you have and what serail to usb cable? I need names.
i cant find the port settings
Username: Concorde
Post Number: 16
in order to see the com ports you need to plug the cable first and of course install the drivers
Post Number: 7
i have a hp laptop and a moschip serial usb chord i installed the drivers but it still doesnt do anything my laptop says that the device is working properly but it doesnt do anything
Post Number: 8
i already did that but it still doesnt do anything
Username: Concorde
Post Number: 18
Here is what you need to do
Go to the vendors website and find the latest dirvers for the os you are using and install it. then go back to step number one. if you still dont get the com port show is cause the os simply does not recognize the drivers. you need to buy another cable but not just any cable you need to buy a cable that your receiver can talk to. there are lots of cables on the market today and even if you have a cable that the os recognizes does not waranty that the receiver will be able to tranmit data or viceversa to the laptop. Before you buy a new cable go to a forun search engine and find out which cable works for the receiver you are using, otherwise you are going to lose your money again.
