Cools@t 6000
Username: Ricky911
I have a 3 weeks old Cools@t 6000 and I have 140+ local channels. I downloaded bin 122(current is 123)and I still have all my channels. Does this mean I will never loose these local channels. Could someone confirm that I didn't waste $240 bucks(CAN). Thanks!
Username: Min
Post Number: 78
RICKY , nobody know that yes , those channels will stay for a while for now or later DN may pull them all out and we all have black screen to watch . Don't know yes waite and see what gonna happen ......
Username: Ong_tu
Post Number: 31
I have had them on for awhile but have lost a few every day.Anybody's guess!!!!
Username: Ticat900
Post Number: 34
I wonder why a 6000 works and not 5000.I lost all my channels aweek ago and so did everyone else??
Username: Woofy
Ontario Canada
Post Number: 247
They work fine with my 5000.
Username: Ticat900
Post Number: 35
rob?? sat 119 or 110??.or combo of both?
which has the most channels??
Thanks
Username: Tadon
Dover, NJ Usa
Post Number: 95
"... I have a 3 weeks old Cools@t 6000 and I have 140+ local channels. I downloaded bin 122(current is 123)and I still have all my channels. Does this mean I will never loose these local channels. Could someone confirm that I didn't waste $240 bucks(CAN). Thanks! ..."
My opinion is, you will have two options:
1 . No, you don't wasye $240.
If you pay $240 for to learn something or
you play with technology ... satisfied .
2. Yes, you are wasted your $240
If you think much for PPV ... when you buy .
I think, depend on people, it will make them satisfied. So one who buy receiver (hit this situation) that is losing money anyway . Why do not think in a positive way ?
I bought 2 Receivers but I only used one connect to TV for my family . The other one
use for my work with a disk on my roof for verify something when i need... I am not worry/angree ... with any situation ... So I am happy :-))))
"dont worry, be happy" :-))))))))))))
Username: Ticat900
Post Number: 36
Thanks
Username: Woofy
Ontario Canada
Post Number: 248
both do pete..channels in the 7000 to 9000 range.
Username: Teegor
Toronto, On Canada
Ricky LeBlanc, You paid too much for your Cool-sat, the rate is CAD 160 to CAD 190 depending on the retailer. Nothing wrong with C5000. Cheers. T
Username: Ricky911
Thanks for the input guys!
