Compass readings for dummies...
Username: Rcajun90
Hi I've had DirecTV for eight years and the trees in my yard are starting to do me in. I can't hit the DirecTV HD satellite. So I'm looking at going with Dish. Well I know I can hit the 110 and 119. I can't hit the 129 because of a tree. I got excited when I saw that Dish also uses the 61.5 satellite. I at first thought it was 61.5 east which of course I have no tree in sight but I knew that couldn't be right. If I stand due South and I see the 110.w, 119.w and 61.5w on the compass housing that is where these sats are located in the sky right? So 61.5 is closer to due east than 110? Or it is off to my left standing due south where it says 61.5 on the housing of the compass. Please help I don't want to go back to cable.
Username: Navy_seabees
using the process of elimination,i think that the correct answer is D.
Username: Rcajun90
D?
Username: Dixon_buts
Moon Base Alpha 1, Red Square Mars
Post Number: 61
Put the dish up higher than the tree.
Username: The_wank_artist
Post Number: 1181
Go here. Take a pin and stick it into your monitor where you would live on the map and then plot it from there. I guess you don't really need a pin, you could use your finger? Or use a magic marker.
Anyway, try this link that tracks the echo3 bird...
http://www.lyngsat*com/tracker/echo3.html
Username: Rcajun90
Thank you!
Post Number: 1186
You could always invest in a chain saw????
Even better if they are your neighbors trees! LOL
