Missing PPV channels?
Username: Zane360
im currently running BIN 277T for a pansat clone
and everything is up and running but im only getting 4 PPV channels from 119.
any ideas???
Username: Zane360
pansat 2500a clone that is!
Username: Zane360
nevermind, it looks like a lot of PPV channels got moved over to 110, did this happen recently?
Username: Grimreeper
Post Number: 134
119 only had 5 ppv movie channels
Username: Babakhan
Post Number: 136
Go To Menu and do Factory reset..then scan ur 119 again...
Username: Evadelparaiso
Puerto Rico
Post Number: 1124
and check your diseqC configuration, maybe do you have bad configuration.
Username: Salem
hello all ,, can any one please tell me the codes for the channels .. please please
Puerto Rico
Post Number: 1128
salem the codes in the new bin are included with autoroll feature enable. Which box do you have? Which bin have the box?
Username: Salem
fortec star lifetime ultra is the box
Puerto Rico
Post Number: 1163
salem: the latest keys are: N 0101 01: (active)
71 9C 60 71 04 C1 39 AE 88 FF F0 5E D2 4C F3 FC
Username: Salem
omg thank you so much ,, your the best
Username: Salem
thank you so much....
your the best
Username: Salem
so EVA when ever I am misssing the ppv channels or any channels just put in the code? And i will get then back?
Username: Lklives
Post Number: 3571
Performing scans or adding chnnel lists are the ONLY ways to retrieve SOME missing channels..
New keys (aka codes)...hell they are NOT codes, there are KEYS!...new keys will return ALL the channels when DN oe Bev changes the keys...Keys will NOT return just SOME of the channels, like PPV's!...ONLY scans can retrieve some missing channels..or a new channel list file loaded using channel master or gtools programs....
Username: Letmeon
Post Number: 35
110 has the majority of the PPVs. best to have 110 and 119.
Puerto Rico
Post Number: 1166
Salem run the latest bin for your receiver if you still have problems.
Username: Salem
ok thank you ,,, your genius/...
Username: Salem
Post Number: 7
guys please help every time tunr off the fortec star box it keeps saying searching for picture or no singnal and i always have to turn off in the back to gte the channels back ,,, please help
