Koolsat 4000 pro - duplicate channels
Username: Ikki
CA
I loaded the NORW 123 and have about 3 of each channel. Every time I load a new bin or scan channels this happens. Is there an setting to not import duplicate channels or an easier way to delte the duplicates once imported other than deleting manually one by one?
Username: Electro99
Post Number: 57
hey set up in options everything on exept sort by sid then do the auto scan !!!!! do not make blinde scan !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!
Username: Dixon_butz
New york, New york United states
With full names you shouldn't get any duplicate channels. You must have poor signal quality. This is a sign of great quality on some dishes and poor quality on the others sort of an imbalance.
Username: Ikki
CA
Post Number: 7
Thanks for the replies. I have tried reseting factory setting, loaded NORW 123 bin, and auto scan with short as well as full names. I keep getting duplicate channels as well as no PPV. Oh well. I get most everything else.
Username: Woofy
Ontario Canada
Post Number: 179
Turn off auto tp..delete all channels then do a new auto scan .
Username: Lklives
Post Number: 3318
U should be getting PPV's...are U talking Bev or DN PPV's?...download another copy of that 123 bin, yours could be corrupted...if U set the factory default, U should lose ALL the channels and have NO duplicates when U do the autoscan..also leave the autorolls ON so U can get the PPVs...
Username: Woofy
Ontario Canada
Post Number: 180
Right on..he needs to do a factory reset.
do a factory reset,, with the remote,,
check,,and go thru your settings,,
turn autotp update-- off
make sure autoroll is on ,,
auto scan your sats with network on.
Username: Lklives
Post Number: 3320
here a factory reset..
1 push (Menu )on your remote it will take you to set up page, you gonna see
instalation
system setting
chanel
game
system info
2 highlite on (system setting) push ok on your remote
3 it will ask enter pin push 0,0,0,0 that number is factory setting (u may have diff number push that # )
hit ok again it will take you to another page you will see factory set
highlite then hit ok it will reset all your chanel
Username: Ikki
CA
Post Number: 8
Thanks again. Got all the channels but the duplicates still came thru for some reason. 2 copies of each channel. At least I got them all.
thanks again
