Pansat 3500 Freezing and Restarting????????
Username: Zagros
Post Number: 25
I installed bin 352 on Pansat 3500SD. Now it keep freezing and restarting. Any solution?
Username: Evadelparaiso
Puerto Rico
Post Number: 890
TUrn back buttom off, try reflashing.
Username: Dixon_butz
New york, New york United states
Post Number: 9
Flash it with the 145 bin then flash it with the 352 bin. The 350 and 351 bin will make your box reboot if you had any of these two on last flash with the 145 bin then the 352 bin.
Username: Googi
Ontario Canada
Post Number: 54
upgrade bin I would say .......BEFORE it's too late, cuz that was happening to me and my pansat 3500 stopped working and never turned on, so get yourself a new good bin http://www.dsstester*com/files.php?cat=14
