NEW Pansat Bin's Are here and working
Username: Argeelh
Post Number: 22
All I have to say is
WE ARE BACK UP AND RUNNING THANKS BL
Enjoy the new bins that were released this mornning. I have tested for 110, 119 and 61.5 and all is back P0rn and PPV's
That is a good start for the World Cup Yaaaaaa
Username: Argeelh
Post Number: 23
here are some files and links
http://www.future-fta.info/f0rum/
Remove the 0 from forum.
All pansat files are under File downloads in that section
Username: The_wank_artist
Post Number: 798
Any word on the BEV ECM. Does it fix that too?
I'm no where near my receiver right now or I'd check myself.
Username: Prar69
Hey Stealth, do you know if it works for 2500a clones?
If yes, can you please point me to it??
Thanks
Username: Argeelh
Post Number: 24
I think it takes care of all Bev and DN issues. I only tested for DN this mornning before going to work.
Username: Argeelh
Post Number: 25
I really do not know you just have to test it
Username: Me2eternity
Post Number: 12
it works on all the channels.......Bell PPV VENUS XXX... have fun !
Username: Newfiebax
all bev working on pansat 3500sd all ppv and p*rn
Post Number: 799
@ fank..
This new bin looks like it is for authentic Pansats only at the moment.
If you load the new bin you might do damage to your receiver, though there are always ways to correct it. You can try it (might fry your box) or wait a few more hours, which is when I'd expect to start seeing new clone safe bins.
Username: Zunna
Post Number: 13
will it work for pansat 3000??
Username: Poison
Post Number: 17
Zunna
It won't work for pansat 3000. As Tyler said wait few hours for new clone safe bins.
Username: Bertoro
Toronto, Ontario Canada
Post Number: 58
thanks for the good news...where do i get the bin? what is the number please?
Username: Poison
Post Number: 19
Ferenck,
which pansat do you have?
Username: Zunna
Post Number: 19
thanx poison
Post Number: 807
News is coming in fast.
Check out this post, 2nd one down, on clones and the new bins.
https://www.ecoustics.com/electronics/forum/home-video/233344.html
Username: Bertoro
Post Number: 59
thanks...my pansat a 2500
Post Number: 808
From DSS Central.
Pansat6000-X-6095BL_060609_3122_E
0 rating out of 5 (0 votes)
Pansat 5000-X-95BL_060609_3097_api
Pansat3500-X-05BL_060609_352eubx_api_au_1
4.5 rating out of 5 (2 votes)
Pansat 2700-X-87BL_060609_272_api_2
5 rating out of 5 (8 votes)
Pansat2500a-X-85BL_060609_277_au_api_
3.5 rating out of 5 (8 votes)
Pansat2300-x-75bl_060609_255e_api
4 rating out of 5 (1 vote)
Username: R1010
Post Number: 33
hi guys i see some good news can any one tell me plz who and where to get i have dish 61.5 and i read (Stealth )you wrote that the new bin ? plz can you or some tell me what is bin and who i can install in to my reciver i will be waiting for some ones help thanks
Username: Dxv1988
MA
Post Number: 34
Thanks guys
Username: Bertoro
Post Number: 60
again..please where so i get the bin? 277 i got it..but where from?
Username: Heroman
Somewhare Nearby, Florida Whocares
I need info to where direct the dish in order to get 110 and 119 satellites.
Username: Mav444
Post Number: 24
ds#scentral # =s has all the bins you need
Username: Icsolutions
I have a PanTec 2500 Ultra, will the Pansat 2500 Bin file work for this clone?
Thanks
Username: Hicham
i want to know if its working for pansat 2500, and from where can i get the bin (web site pleazzzzz)
thanks all of you guys
Username: Evadelparaiso
Puerto Rico
Post Number: 747
zaza read above. Its Safe for all pansat. Download the bin, at dss***tester.com remove ***
and follow these Steps: For ALL Pansats....
Things you will need!
1.A computer with a com port!
2.The right cable to connect to your computer to your receiver!
3.The most recently LOADER
4.New pansat bin!..
5.LNB setup and the right switch!
6.Sat Signal at 70 percent or higher!
1.Power down receiver and computer!
2.Connect receiver to computer and power both of them up!
3.Start up gtrom newest version and select the new bin file you wish to upload then click download wait until it is finished it will go to a 100 percent but it is not finish until it displays burn complete or finished!
4.Turn off power to receiver and computer and remove the cable from the receiver!
5.Install cable from the lnb and the cable from the tv and the plug it up and power up the receiver!
6.Using your remote hit menu and the parent control then ok in second pin enter 0000 and then ok!
7.Then set default key..EMU-ON then ok!
8.Go to Nagavision2 then ok and check 00 and 01 keys. Put in new keys if need then hit ok to save!
9.Now installation then ok antenna setup then ok make sure you have 110 and 119 and check to make sure the switch is set right for both on the diseqc setting! If 110 is on 1 and 119 is on 2, set diseqc the same way!
10.Now go to blind scan and hit ok!
11.When finished exit menu and watch tv!
Post Number: 836
zaza,
get it at dsscentral*net.
Yes the bins are working on authentic Pansats.
Clones of pansats are risky, and no official clone bin has been released yet. Your better to wait for it if you do have a clone.
I am a new member and new at this, would some one tell me if the pantec 2500 ultra considered a clone of the pansat and I'll need to wait for a new bin or is there something out their that I can download and use. Please help.
Thanks
Post Number: 838
i c,
it's a clone.
Thanks Tyler. Any recommendations at this point?
Username: Suniljee
Post Number: 16
hii guys where is the BL going on no good news for a fortec star ultra .. anybudy have a good new for it plzzzz let us know thanks
Username: Saltyswift
I loaded the new Pansat 2700 bin this morning.
BUT, I need to know how come some international channels are not working with the new bin?
2 channels that I'm interested in are Polsat and ITVN are down.
I did a blind scan on Echo3, but they're still black.
Anyone know why?
On my autoroll menu, I have keycode, Dishnet, BEV and GlobeCast all set to ON.
Should I change something?
I already pressed Set Default Key and I'm getting all channels EXCEPT for Polsat and ITVN.
Anyone know why?
Could this be because of World Cup?
Has anyone heard of channels being hashed as they show World Cup games?
Thanks all!!
